Last Post: joes95bobber
0 Cam question
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
Last Post: dodgetrucken
Last Post: oldboy
0 Bike Beast
0 Old new guy
0 strange noise in top end
0 Oil leak
Last Post: Roane
Last Post: felis
0 BSA to be reborn...
Old 6 Days Ago
Gold Member's Avatar
Gold Member Gold Member is online now
Sportster/Buell Year: 1972
Default mainshaft rollers size
I have a bag of 100, 9095 rollers that are supposed to be .1562 OD, and a check of the first 6 I took out of the bag miked .1563. Is this a problem?
I know somebody here said if 2 out of the 23 are 2/10 over, that can cause them to skate. I'm wondering if all of them are 1/10 over if this is too tight.
Stop by my build thread:
Old 5 Days Ago
Arithmetic: isn't .1563 1/1000 over .1562, which is way smaller than 1/10?
Old 5 Days Ago
Nope, synthetic oil is what makes them skate.
Old 5 Days Ago
randy3934's Avatar
when measuring down to .0001" ambient temperature has an effect, just holding them in your fingers will change things hahaha.
Old 5 Days Ago
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
Si
To measure +-.0001 temperature is a factor. Also need to check your micrometer against a known gauge.
Shops doing aircraft/military work have to send their gauge blocks out every year to be certified. Then they can use them to calibrate their measurement equipment.
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
Old 5 Days Ago
Getting back to the original question, " if all 23 rollers are .0001" oversize will it be too tight?"
It's impossible to answer without knowing the exact ID of the race.
Old 5 Days Ago
really roller size is moot. you must fit the race to the roller, fsm.
Old 5 Days Ago
Yes that's true.
I think Goldmember was asking if he could put slightly oversize rollers in without honing the race bigger. If he already had standard rollers at an unusually large running clearence then it's POSSIBLE he could and end up with an acceptable running fit without touching the race.
But we don't have all the facts. The size and condition of the race or if it's a new race and why he even needs new rollers. So he asked a question that can't be answered, yet.
Old 4 Days Ago
bad mojo
new rollers in an old race, better have some GOOD measurements
i am going to the trouble to install new rollers, a new race will be fitted.
would you put new bearings on an old rod pin???
might see daylight out the bottom.
not a time to cheap out.
Old 4 Days Ago
No, I agree. It's not my build. Don't know exactly what Goldmember has got going.
