0 82 XLH struggling for power
0 -65A mufflers
Last Post: a-sad-anorak
Last Post: leon bee
0 MS rollers way too tight
Last Post: murphdog
0 Tools
0 Zippers 1250 kit
Last Post: wardie
0 my daily driver
Last Post: 84rzv500r
0 Newbie
Last Post: BitterOldMan
0 OEM Headlight Bucket?
Last Post: spoon
0 KBS tank sealer
Last Post: mrmom9r
0 100 vs 110 front tire
0 mainshaft rollers size
Last Post: PappaBravo
Last Post: jcro61
0 my sunday driver...
0 Now running 3.40 factory gearing
0 carbs?
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
If you can simply "insert" the 23 rollers and have no play in the shaft or have no binding of the shaft you should be good. Tapping in a roller is a BIG NO
Arithmetic: isn't .1563 1/1000 over .1562, which is way smaller than 1/10?
the professional machinists haven't answered this so the amateur machinist will attempt.tenths hundedths thousandths tenth thousandths.the fourth digit put's it beyond thousandths.5 tenth thousandths is half of 1 thousandth.
Yes, and when the professional machinists talk about ten thousands of an inch they shorten it to "tenths". So they would call .0006, "Six tenths." Which of course causes confusion because .6 is really 6 tenths of an inch. They would probably call .6, 600 thousands. Same value.
So machinists are too lazy to say "ten thousands of an inch". and everyone doesn't know what they're talking about. Damn machinists.
right.they often shorten thousandths to say''thou''. 6 thou.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: Cyclone
Other Motorcycle Model: FXDC
Tenths.
.0001 One tenth
One ten thousandths of an inch
I was questioning the accuracy of the measurement. Not trying to be a d*ck, but that is damn small. Temperature will affect it
Steve
'03 Sportster NRHS 1250, Mik 42 HSR, SE 536, Dyna tech nosecone stage two lightning heads, supertrap 2/2
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I think we pretty much all measure parts in our temperature controlled clean room.
I run mine at 75F and 50% humidity*, Others may prefer other settings.
As long as you stabilize everything before you do the measure or cut you'll be fine.
* - my carpenter recommended this to me. It's what he uses.
Steve9's Avatar
ISO standard: machine parts are measured at 68* F (1931)
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
You know, that's the first time I've seen it written in F and not C. haha
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
Steve9's Avatar
Yeh, I think in F
Much more comfortable than having to work at the melting point of ice...
Ham, porkchops and bacon all come from the same magical animal?! That's crazy!
