0 82 XLH struggling for power
0 -65A mufflers
Last Post: a-sad-anorak
Last Post: leon bee
0 MS rollers way too tight
Last Post: murphdog
0 Tools
0 Zippers 1250 kit
Last Post: wardie
0 my daily driver
Last Post: 84rzv500r
0 Newbie
Last Post: BitterOldMan
Last Post: Andy56
0 OEM Headlight Bucket?
Last Post: spoon
Last Post: jon1966uk
0 KBS tank sealer
Last Post: mrmom9r
0 100 vs 110 front tire
0 mainshaft rollers size
Last Post: PappaBravo
Last Post: jcro61
0 my sunday driver...
0 Now running 3.40 factory gearing
0 carbs?
  #91
blk80bike blk80bike is offline
blk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enough
I ended up buying a tank today on ebay. Maybe some of you had also seen it. I'm pretty sure its an 80 Xls gas tank in the correct colors.
With the shorter front horns with a hole. Someone placed some big tank stickers from the mid 80s- 1985 Fx right over the top of the tank HD logos still there.
Now I need to find a complete rear mounting set for the XLS/FX. Its crazy the replacement kits run around $80 new...back to watching Fleabay.
1980 Sportster XLH 1000
It has been quite a few years since but J&P Cycles used to have those mounting kits. They were for the SuperGlide tank and work for the 1980 XLS tank.
waiteitei's Avatar
waiteitei waiteitei is offline
Sportster/Buell Model: XLH - Rowe Frame
waiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of lightwaiteitei is a glorious beacon of light
I use an intake rubber o-ring instead of the spring and clips to hold down the back of the tank . Attach it gently on one side, pull it thru to the other side with a 90` hook - like a snap ring pliers.
Great tip
Used that on my 80 XLS many years ago and used that on my current bike that has a superglide tank on a Mark Rowe Framed sporty
