Last Post: ericfreeman
Last Post: Rollbar
0 strange noise in top end
0 Cam question
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
0 Swingarm Bearing ID?
Last Post: motorfish
0 windshield on a Custom
Last Post: Eric Von Zipper
Old 23rd January 2013
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
The Superglide tank was originally an Aermacchi/Sprint tank. But the Aermachhi/Sprint also used several other tanks over the years, so you have to make sure to get the right one I guess.
1980 Roadster tank, also used in 1981. Similar to SuperGlide tank; i think the front mounting horns may be a little different but i am not certain ...
ericfreeman's Avatar
ericfreeman ericfreeman is online now
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
My XLT came with the factory Superglide tank but I cut down the front horns a little for a cleaner look. Horns aren't necessary on the XL's.
I have the original tank from my XLT along with a couple sets of saddle bags, including all brackets. Even the very hard to find turn signal bar that bolts to the rear fender. I'll never use them so let me know if you're interested. The bags are currently painted black (by previous owner) and will need repainting or stripping down. I also have a couple of OEM oil tank decals as well.
Here's a pic of the Superglide tank I repainted for my XLT. I've also included a pic of my XLT. Note that I don't run a windshield and the pipes, carb and seat are not stock. I painted the saddlebags when I sprayed the rest of the bike and like the look of the painted bags.
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
All '69 to '72 Sprints came with only 1 tank style (aka: Superglide). On Sprints they were entirely rubber mounted (no nuts, bolts, screws, or clamps). A Sprint tank has less capacity than a Superglide tank because of the Air cleaner recess on the left side.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
I use an intake rubber o-ring instead of the spring and clips to hold down the back of the tank . Attach it gently on one side, pull it thru to the other side with a 90` hook - like a snap ring pliers.
Mick they ran that tank till 1982 , in 1983 they change tanks. Nikki
the difficult can be done immediatey the impossible takes a little longer
81Fe's Avatar
81Fe 81Fe is offline
Sportster/Buell Model: 1969 XLCH
Sportster/Buell Year: 1969
Sportster/Buell Model #2: XLH 900
Sportster/Buell Year #2: 1965
Other Motorcycle Model: XLH 1000 75th Anniversary
Other Motorcycle Year: 1978
81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of81Fe has much to be proud of
Originally Posted by chadpm View Post
1985. Bolt on Turtle Tank.
I know you said "bolt on", but my '83 sure doesn't have a rear mount on the frame that far back...
Did anyone ever figure this out?
I think where the post-1982 frames 'split' where the oil tank and battery go will prevent the turtle tank from being installed... but I'm not sure...?
I know this is an old thread, but I'm in need of a new daily driver commuter bike... and I'm thinnking that a rigid nount Evo sportster with a Turle Tank will be the ticket. (This is not a thread about what bike I should choose to daily drive... its about the Turtle Tank)
I have a Turtle Tank that is pretty beat up (but fixable) to use for the project... but I have not bought the Evo Sporty yet, and I want to see how this will work out...
EDIT: I sold the 1982 that I originally started this thread about, so I can not use it as a mock up frame...
Fear no Evo.
Monkeywrencher's Avatar
Monkeywrencher Monkeywrencher is offline
Sportster/Buell Model: XLSa
Sportster/Buell Year: 82
Sportster/Buell Model #2: FLHTC
Sportster/Buell Year #2: 1987
Monkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished road
[quote=nikki;4302317]
[/QUOTE Mick they ran that tank till 1982 , in 1983 they change tanks. Nikki
Yep, This is the same tank on my 82 XLS.
nikki's Avatar
when I put the fat bobs on my roadster I mounted two pieces of 1/4 inch flat strap to raise the mounts to work with the tank , the same can be done for the turtle tank on the 82 and up frame all anyone needs to do is to think a while and a way will come . Nikki
81Fe's Avatar
I'm fine with making / welding brackets... but your suggestion of raising the stock mounts simply wont work with a Turtle Tank on a 1982- up frame.
The rear mount on the Turtle Tank will sit about 1.5 inches to the rear of where the frame makes a "Y" in the oil tank battery box area. Based on measurements I took on my 1982 I'm sure of this. It may be as simple as making new brackets and welding to the frame, and this is what I'm hoping for.
BUT, I think the mounting tabs on the Tank will hit the 2 sides of the frame "Y", which will require cutting and re-working the tabs on the tank. I do not know how wise the frame "Y" os 1.5 inches behind the split... which I guess is what my questions should have been. (I do not currently own a bike with this frame style, otherwise I would just mock it up)
I'm NOT willing to cut up such a rare vintage piece as a Turtle Tank.
nikki's Avatar
BUT, I think the mounting tabs on the Tank will hit the 2 sides of the frame "Y", which will require cutting and re-working the tabs on the tank. I di not know how wise the frame "Y" os 1.5 inches behind the split... which I guess is what my questions should have been.
You missed what I meant that was what I need to do to fit the fat bobs , the turtle tank may require you to drill the frame , putting a piece of tubing in the drill hole then run a bolt thru the tank mount , hole and the tank mount . get to get together with some of your bro and kick this around . Nikki
