0 early 73 vs. late 73
0 Repair Manual?
0 High RPM cutting out HELP!
Last Post: Windtheropy
0 Greetings from central Illinois
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: eimkeith
0 Help: Weird electrical gremlin 08 Nightster
0 Lost compression?
Last Post: davixlrtt
0 Replacement clutch discs
0 90 vs 89 ape hanger kits
Last Post: Four Speed
0 WTF Happened
Last Post: 3dognate
0 Forks
Last Post: Pezed
Last Post: lugster
0 Touring CX Roadster
0 **DK Custom- *NEW* Sportster Slip Stream Skid Plate-10% Introductory Savings**
0 Lake Erie Ride Alums?
Last Post: bplinson
0 starting characteristics
Last Post: GaryanOdinson
0 Shotgun Porn
0 Missing Man - SE Missouri Area
0 Wauseon 2018. Who's going? Picture thread
Last Post: Pickss
0 Speedo quits working, bike wants to die
Last Post: ReddTigger
0 Plug wire question
Last Post: myrl883
0 Danmoto Highwayman Sportster 1988-2003 exhaust
Last Post: bimbo
oakies, Gunhappy2 (60), SamIam (54), biggdann (48), boyer911 (48), danii (41), PVD24 (39)
  #141
1Scooter 1Scooter is offline
1Scooter is an unknown quantity at this point
Baffles in the drag pipes are exhaust restrictions. Foo Foo valve is a crankcase breather valve. Open or baffled exhaust has nothing to do with crankcase pressure.
Old 6 Days Ago
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud ofFridge has much to be proud of
"Always heard engine needs a little back pressure? Is that the same with this set up?"
By set up, can I assume that you are meaning the Harley Davidson, 45* twin cylinder, single crankpin engine?
If so, then YES, back pressure is very important.
If I could be so bold as to tell my story, which starts with,
standard 1-3/4" drag pipes, to wrapped drag pipes, to 2" drag pipes, to 2" drag pipes wrapped, to 1-3/4" wrapped drag pipes with cored out slip on mufflers, to an OEM crossover pipe header for an 83 Ironhead and cored out slip on mufflers.
The engine absolutely loved the last setup for best flow, torgue and all round giddy up and I absolutely love the set up as well.
Try it, you and your engine may love this set up also.
Old 6 Days Ago
on½....'s Avatar
on½.... on½.... is offline
Sportster/Buell Model: xlch kick
Other Motorcycle Model: cbr600rr on½
Other Motorcycle Year: 2008
on½.... will become famous soon enoughon½.... will become famous soon enoughon½.... will become famous soon enoughon½.... will become famous soon enoughon½.... will become famous soon enoughon½.... will become famous soon enoughon½.... will become famous soon enough
Thanks brucstoudt I wasn't even thinking of that. so focused on the pressure cooker lol. With that in mind Yup i'm just going to take them out. With what i've been seeing hate for it to blow some seal inside the engine. I'll report back the difference going down there now. Really curious if that baffle is the cause of the valve spitting. That it needs that free flow.... Maybe it will stop unseating the rear exhaust too. haha
Old 6 Days Ago
on½....'s Avatar
Thanks 1Scooter, I wasn't sure as every time I do something on the bike it sends the problem to another part lol. Tighten this rattles something else off lol. Was thinking there has to be a little bypass like the oil transfer in the case to the primary... Say the back pressure pushing on the rings, changing the case pressure cause ring bypass to smoke out the valve? idk
Fridge, yup that is the one. I got these drag pipes with the bike, maybe slip on be better route than the baffle later on.
Been keeping it going rather than full tare down
That first ride opened my eyes. Its like I adulted the bike with the baffles for the past 2 years, feel so sorry for the bike.
Thanks so much guys.
Will look in different direction as to why smoking out the valve after small ride.
Old 2 Days Ago
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
That's the same setup I have on my '83. Along with an old SE air cleaner kit, Andrews accelerator pump, and a carb rejetting, it performs very well.
