0 Value of a Boattail?
Last Post: valvebeater
0 Future of the sporty?
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 Paulie420 needs your help.
Last Post: Paulie420
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Not charging issue!
0 so,, amazing,,how u guys are sucking,, knowlege
0 HAMMERPerf 90" In the Works
0 Range With EFI 4.5 Gal Tank
Last Post: jzink0883
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
0 Joe Minton article on HSR 42 tuning
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
SoCal 1200N (57), riverar7 (53), rx3732 (44), gnrxl2002 (40)
Old 17th June 2010
COON's Avatar
COON COON is offline
Sportster/Buell Year: 1976
COON is an unknown quantity at this point
Unhappy 1976 sporster clutch problems
Here we go again ... I have a 76 xlh i installed a new clutch for old ones were burnt and steels were warped ....i adjusted it twice according to factory manual ...hers the thing clutch does not disengage .....put it in gear hold clutch in still turns motor over ...also have replaced ramp kit and new cable ..this is same problem i had before replacing clutch
Old 17th June 2010
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
If you mean that the kicker/electric starter turns the engine over even with the clutch lever pulled, that's normal. If you have it in gear, pull the clutch lever in, and hit the starter, does the bike itself move?
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb socket genuine Aftermarket rear fender generic countershaft sprocket Radio Shack 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 17th June 2010
COON's Avatar
Even if its not running you can tell its not disengaging and yes starter will move bike when you hit button with clutch pulled in
Old 17th June 2010
COON's Avatar
With bike off in second gear clutch pulled in if you hit starter butoon bike trys to take off
Old 18th June 2010
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
clutch is sticking , mis-installed, adj. improperly I`ll pm a cell in case you want a walk thru.
Old 18th June 2010
COON's Avatar
Double checking will let you know what i found out ...otherwise my call tomorrow
Old 18th June 2010
piniongear's Avatar
piniongear piniongear is offline
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
piniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to all
I am assuming you did the adjustment correctly, so....
Just do like you are supposed to and start it in neutral.
Then roll it down the driveway and hop on. As it is rolling put it into first gear and ride it around the block. Better now?
pg
Old 18th June 2010
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
This is normal. The starter runs on the ring gear on the clutch basket, which is connected directly to the primary chain.
A better test is to put it in gear with engine not running, pull in clutch and see if you can push the bike forward. Even then, a new clutch will often drag until you have ridden it for a bit and bedded in the new plates.
So take it for a ride and see how it goes.
Old 19th June 2010
Dennis72184 Dennis72184 is offline
Dennis72184 is an unknown quantity at this point
I recently did mty clutch and had the same issue, ended up needing washers behind the pressure plate. I guess since the stuff was all new it needed more clearance to disengage. Drove me nuts but that solved the prob.
Old 19th June 2010
BOB ROSS BOB ROSS is offline
Sportster/Buell Model: custom xl
BOB ROSS will become famous soon enoughBOB ROSS will become famous soon enoughBOB ROSS will become famous soon enoughBOB ROSS will become famous soon enoughBOB ROSS will become famous soon enoughBOB ROSS will become famous soon enoughBOB ROSS will become famous soon enough
how long does it take to break in. i put new clutches in mine having the same problem with adjustment
bob
