0 The country store
Last Post: lugster
Last Post: rjg883c
0 headight housing
0 Future of the sporty?
Last Post: VaFish
0 Diagnostic help
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
0 Fork oil capacity for 2008 XL1200R
Last Post: guitarfish
0 Weekdays in PA, MD, DE (ETC.) - Meet & Greet - One Day Rides
0 Speedometer Damage
0 new oil lines
Last Post: Dave L
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
0 Shop Trick of the Day: Proper Welding Techniques
Last Post: BILLETPROOF
0 first harley- help!!
Last Post: Joesdaddy
Last Post: Blowupster
0 oil cooler or not?
0 Intro from New England
Last Post: oreocat1
0 HAMMERPerf 90" In the Works
Old 16th June 2010
bryguy1977 bryguy1977 is offline
Sportster/Buell Model: xls sportster
Sportster/Buell Year: 1979
bryguy1977 is an unknown quantity at this point
Default S and I ????? starter relay Q
ok my 79 xls f/m shows starter solinoid relay with 3 termanals 2 big 1 small, on the one they gave me at the shop has 2 big I know where they go and 2 small one marked S and the other marked I ,I need to use one of these witch one? I watched a video , (for a car starter relay), and they said dont use the s term only the I , what the heck termanal do I use and what's the other one be for? thanks
Old 19th June 2010
stanjj2004 stanjj2004 is offline
Sportster/Buell Model: Sportster - unknown
stanjj2004 is an unknown quantity at this point
did you figure it out?
Old 19th June 2010
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
I'll have a look when i'm in the shed later, if it mounts up under the battery box like my 77 does, you use the small terminal towards the front of the bike. I'll confirm S or I later
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 19th June 2010
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
You can test by hooking it up to a battery. neg. to case. pos to 1 of the pins.only 1 should make the relay operate.
Old 19th June 2010
biged biged is offline
Sportster/Buell Year: 1974
biged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nicebiged is just really nice
I'm pretty sure that it's the same as a delco the S (start) term is the one you want the other I is short for ignition and not used it was a momentary supply for the coil on some things
Old 19th June 2010
Here's the line up for the wiring:
Ignition switch lead to S terminal
Ignition lead to I terminal - only use this if the original relay used it as well, if not then don't use it.
