0 Does 20W60 reduce cam gear noise?
0 Hagerty Insurance
Last Post: Pigskinner
0 TC88A EX lower MAP settings
0 Poll: Saddlebag Supports
0 magneto twin plug heads
Last Post: marioserafica
0 Fun or money?
Last Post: bill smith
5 Wet Dream, Ever Have One?
0 Down on oil
Last Post: Billy1200
0 1968 xlch
0 blonde, brunette, red?
0 Hamburger drum brake clunk noise
Last Post: nickfracture
11 How much did you spend on accessories in the first month?
0 I'm here to introduce Gristle.
Last Post: apotheon
Last Post: Randy_rots
Last Post: apotheon
0 Wish I had a beach with a ocean
Last Post: Akdawg
10 big bore question
0 Transmission figment
0 Smoke and top end job
win307 (66), JrzyDave (59), WeirdNJ (59), Pigskinner (46), jeepsoldier (44), Virgdog (34), bernardderek, John Titor (22)
Old 20th September 2017
martymill2 martymill2 is offline
Sportster/Buell Model: xl883l
martymill2 is an unknown quantity at this point
Default Bar riser question
I have a 2013 superlow 883 (xl883l). The person I got it from is very short and I want to put on a riser, how far can I go without changing cables, brand line,etc.?
jzink0883's Avatar
jzink0883 jzink0883 is offline
Master Bike Builder
Sportster/Buell Model: XL1200CP
Sportster/Buell Year: 2015
Sportster/Buell Model #2: XLH1200 (traded in)
Sportster/Buell Year #2: 1998
jzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond repute
marttymill2,
Your stock riser bolt is #3605 (1/2-13x2.5, Grade 5):
- Get longer bolts
- Get a bunch of 1/2" washers
- Use stacks of washers under your stock risers to see how much higher you can go with stock cables, wiring, and brake line
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
wedge's Avatar
wedge wedge is offline
Originally Posted by jzink0883 View Post
marttymill2,
- Get longer bolts
That's F'n Brilliant!
This is what this forum is all about. You should get a bunch of rep for this simple yet brilliant solution to all the measuring we have all done in the past. I can't give you rep now, because I just did on something else.
felis's Avatar
felis felis is offline
Sportster/Buell Model: XL1200CX Roadster
Sportster/Buell Year: 2016
felis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond reputefelis has a reputation beyond repute
Ya - that makes more sense than how I do it - just loosen everything up and lift it.
Not the most accurate way.
On my '97, I was able to get 6" risers topped with drag bars, and still had a little stretch left.
That's probably only a couple more inch lift than it was stock though.
marttymill2,
- Get longer bolts
the superlow has a triple tree with a slot running thru it your bars sit in, then the riser clamp goes over that(riser clamp consists of the bar with the speedo mount and neutral light, high beam,etc) it's not like a normal tree at all with studs coming out the top so i'm limited to what is available. there's pivoting risers and some 2 inch ones made by LA Choppers. i would like to go with the # inch ones for now
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
I agree. Rep sent.
Folkie
South East England Riders
Folkie's Avatar
Brass Nut
Then use felis's method: undo the clamps and see how far you can lift the bar.
The PO was short? I don't understand that comment.
wkong's Avatar
wkong wkong is offline
wkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to allwkong is a name known to all
take the tank off and loosen all the wiring you can, pull it tight from one direction (from the handlebars or from the seat) and hold your finger on a spot you can track, like the front tank mounting bolt, then stretch it the other direction and put your other hand on that spot. measure between them. might wanna do it at full lock both directions but I don't know if your wires are ran through the bars or what.
anyway, I'd bet my bottom dollar on a 2" extension being no problem at all.
Old 22nd September 2017
I should mention I went ahead and ordered a 3 inch pivoting rider made by Rox Speed from J&P
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
3" riser was all my Nightster would allow with stock length cable and hose.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
