0 Turbo Iron 883
0 Ok 1200 to 1275 for street performance
Last Post: SportyHD
0 Andrews N4 VS Stock D or W grind cams
Last Post: vagrant318
0 Momentary starter switch installation question
0 Problem on a trip
0 Michigan Thumb Run:
0 Stock pipes
Last Post: Eric Von Zipper
0 Wanted: Mid Controls for Frame Mount Evo
Last Post: 5mel42
0 Craigslist
Last Post: Bikeaholic
0 How packed is your garage?
0 No oil flow
0 Reflectors...Yeah, or Neh
0 Where to Buy a Quality Fuel Tank
0 Laughing shotgun pipes...Kickstarter hits pipe
Last Post: cazz1000
Last Post: Joe_jeep
0 Hello from Canada!
Last Post: Piper01
0 Michelin Commander 3
Last Post: ivanford
Last Post: ivanford
0 Cam position sensor
0 New shocks (Drag Specialties)
Last Post: Lone Rider
billydale (77), twoqk4you (60), MMILLS69 (46), aaaugie (46), MikeyT (45), chardhin, jjphoto (42), promiscuousman (36)
View Poll Results: What weight fork oil do you use
5w 40 9.62%
10w 87 20.91%
15w 115 27.64%
20w 40 9.62%
30w 16 3.85%
standard weight HD 76 18.27%
Screamin eagle HD 52 12.50%
Multiple Choice Poll. Voters: 416. You may not vote on this poll
Old 26th May 2007
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Changed to Bel-Ray 20 weight and Progressive Springs up front.
Always had a vibration-free ride but the change made an even better ride.
Progressive 440HD 13.5" shocks are arriving this coming week. Have to see how they do.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 27th May 2007
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
Originally Posted by XLXR View Post
This poll is rather interesting. I weigh 230 - 260 lbs, depending on what gear is in the saddlebags. Probably heavier than most other guys. Yet with my forks set up as I describe below, the initial rate of my forks are softer than lighter weight guys, yet the bike handles better. So far, I am the only one using 10 w fork oil.
I've changed to 10w since I voted. It gives me a less harsh ride and still provides enough low speed damping for chassis control.
I currently weigh 173lb.
Old 27th May 2007
Turbota's Avatar
Turbota Turbota is offline
I packed my front forks with lard, but I now have to admit that the suspension is a little hard for my liking.
04 XL 1222R
Old 27th May 2007
pres41's Avatar
pres41 pres41 is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Wifes 883 Custom
pres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the roughpres41 is a jewel in the rough
With my progressive spings in the front I'm running HD 15 wt, opps you say HD don't make 15 wt, they do if you mix equal parts of SE (20 wt) and stock oil (10 wt), works real well in mine.
Pete
2002 "883" (Taxes paid and then some) <G>
Progressive up front, RK air shocks out back
Super Low Bars, and Whats a Harley without bling
Old 28th May 2007
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
10 wt. oil
Old 29th May 2007
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
I started with 15wt. then 10wt. and ended up going to 7wt. I weigh about 190lbs. The 7wt. gives me the smoothest all around ride. I use a little over 1oz. more in each leg, never bottoms out just smooth riding.
Old 30th May 2007
rider1951's Avatar
rider1951 rider1951 is offline
Other Motorcycle Model: Suzuki DL1000
Other Motorcycle Year: 2002
rider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to beholdrider1951 is a splendid one to behold
I first tried Belray 15w but at my 155 lbs. found it too stiff. I'm now running Amsoil medium 10 and the front end feels a lot better. I may try 7w in the future to see if it is any better.
Impact Blue 1200 Custom, Gronk's mod stock exhaust, Ram-Flo 400, 45 slow, N65 needle, 175 main, HD detachable windshield and rear rack/ back rest, lay-down license plate, Mustang wide vintage, Progressive 13 1/2" 418s and Progressive fork springs w/ Belray oil, Superbrace,
Old 30th May 2007
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
I went to Works Performance dual rate springs and the SE HD oil....I think it's 30 wt. I thought it was ok until the temp dropped below about 80 degrees When it was in the 40's....it felt like rigid tubes
WAYYYYYYYY too stiff. Went back to 7-1/2 oz of the OEM and 3-1/2 of the HD....Much better I have since changed forks to the "S" forks and whatever came in them is what I am running.
Like XLXR mentioned....get the springs right then adjust the dampening to suit!
Good Luck
Stuff: YES
Old 14th June 2007
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
Progressives up front with 15 wt....... Good ride, Good corneriing...
Old 17th June 2007
supercharger's Avatar
supercharger supercharger is offline
supercharger will become famous soon enoughsupercharger will become famous soon enoughsupercharger will become famous soon enoughsupercharger will become famous soon enoughsupercharger will become famous soon enoughsupercharger will become famous soon enough
Bel Ray 15w and Progressive springs.
I will change to 10w next to see if I get smoother action over RR crossings. RR tracks seem to be the only "harsh" causing situation I get with 15w. If the 10 makes a difference it stays.
2005 Sunglo Blue 1200 Custom
77hp*78.4tq Stage 1, Prog fork springs, Fox/Harley shocks, Big Sucker, CS tapereds, Shiny Things
"That horse ain't dead till I get through with it"
