0 Free to a Good Home (pay $8 shipping only):2014 FSM, used
0 Lost compression?
Last Post: Fridge
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 1962 XLCH Front Wheel WTB
Last Post: brianbbs67
0 33.4 fork axle help
Last Post: 78ironhead
0 How dangerous is 2k clear coat really?
Last Post: Whitewalls
4 Cross Country Prep
0 Intake manifold gasket fitment
0 Fuel Pump Problems
0 2 wire turn signal installing on 1 wire bike
0 Sportsterpedia Progress
Last Post: Randy_rots
0 How to remove internal throttle cable
Last Post: The Doctor71
0 Carb issues
Last Post: Diogenes415
0 Fact or Fiction - HP Claims
Last Post: jcro61
Last Post: Ridneck1986
Last Post: cotton1
0 Right Angle Plug Caps and Leads
Last Post: Lone Rider
0 End of the road for me
Last Post: jcn59
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: jammantoo
Last Post: lugster
0 Sudden stiff rear brake pedal.
stevervp, philvet (75), outlawreb (63), rabes56 (62), Bigmatt (60), Beaker666 (54), hippiemwc (54), wumm883c (52), 2wheeltodd (51), israel (46), XRWeasel (44), Stitch (41), Dekooy (35), Titaniumrust (35), Ameri-Deutsch (34)
1979, one cylinder, problems, runing rich, xls
Thoroy Thoroy is offline
Sportster/Buell Model: Sportster XLS Roadster
Sportster/Buell Year: 1979
Thoroy will become famous soon enoughThoroy will become famous soon enoughThoroy will become famous soon enoughThoroy will become famous soon enoughThoroy will become famous soon enoughThoroy will become famous soon enoughThoroy will become famous soon enough
Question 1979 Sportster XLS Problems
Hello,
I inherited my dad's old Sportster. It is a 1979 XLS Roadster. It sat for 20 years in good storage because it had stopped working in 95. My dad always planned on fixing it but never got around to it. After he passed I had a Harley mechanic rebuild the engine due to a broken piston rod. it has run pretty well since with a few hiccups here and there. I have been doing a lot of the minor stuff but have run into a new issue I cant seem to solve and hoping someone else has had and solved it. Lately the bike will start and run well for 5-10 mins, after which one of the cylinders stops firing.
the Spark plugs show rich mix so I overhauled the carb. changed the plugs and worked well after for about an hour. then same thing rear cylinder stops firing. I've checked the coil with a multi meter and it is showing as fine. checked the plug cables they are fine.
Has anyone else had similar issues? if so what were they?
Subscribing Biker
Toejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant future
Once your rear cyl. quits firing, pull the rear plug wire (while it is still running) and see if it is still throwing a spark, if not your coil is malfunctioning when it gets warm.
Thanks for the tip ill give it a try tomorrow after work.
Question
Should I go to Harley for a new coil or is there better aftermarket ones that would be better?
Folkie Folkie is offline
Why is this in the 'Photos/Videos' section? Moving to 'Ironhead'.
60weight's Avatar
60weight 60weight is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 79
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 82
60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of60weight has much to be proud of
Dont pull either plug wire while Shes running.
Thats not good for the factory ignition or Yer fingers.
The proper way to check for spark is shut Her off,pull both plugs then install the plug wires on plugs,
lay them on the heads making a ground. Then turn on and push starter button while watching them fer spark.
Before buying a coil,determine what ignition system You have..
Factory,aftermarket brand,or a points system. This determines which coil You need to buy.
And welcome to the Ironhead section
"the Spark plugs show rich mix"
Fouled plug(s)?
