Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
0 Free to a Good Home (pay $8 shipping only):2014 FSM, used
0 Lost compression?
Last Post: Fridge
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 1962 XLCH Front Wheel WTB
Last Post: brianbbs67
0 33.4 fork axle help
Last Post: 78ironhead
0 How dangerous is 2k clear coat really?
Last Post: Whitewalls
4 Cross Country Prep
0 Intake manifold gasket fitment
0 Fuel Pump Problems
0 2 wire turn signal installing on 1 wire bike
0 Sportsterpedia Progress
Last Post: Randy_rots
0 How to remove internal throttle cable
Last Post: The Doctor71
0 Carb issues
Last Post: Diogenes415
0 Fact or Fiction - HP Claims
Last Post: jcro61
Last Post: Ridneck1986
Last Post: cotton1
0 Right Angle Plug Caps and Leads
Last Post: Lone Rider
0 End of the road for me
Last Post: jcn59
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: jammantoo
Last Post: lugster
0 Sudden stiff rear brake pedal.
stevervp, philvet (75), outlawreb (63), rabes56 (62), Bigmatt (60), Beaker666 (54), hippiemwc (54), wumm883c (52), 2wheeltodd (51), israel (46), XRWeasel (44), Stitch (41), Dekooy (35), Titaniumrust (35), Ameri-Deutsch (34)
  #31
Old 21st May 2017
jstoll's Avatar
jstoll jstoll is offline
Sportster/Buell Model: XL1200Frankenbike
jstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant future
its funny... Ive had the C jiffy stand on my bike for like a year and a half with 13.2 rear shocks and never really fealt like my bike was in danger of falling over... I do have some derlin coming and will make a block...
Im a little bummed that this thread has gone to kick stands... there are several threads on kick stands and I was hoping to hear more about shocks and in particular the new HD setup... the progressive 490 shocks I want to get will be 1/4 inch shorter then what I have at 13 inches ...so my bike will be more upright on the stand
Im 50 years old .. not retired and dont always sleep well or type well :-)
take care
JAK
[SIGPIC][/SIGPIC]
05 XL1200F
Frankenbike
Hammer 1250 11:1 30* pistons
Hammer Crush Head service
Mikuni HSR42
Hammer Impact Air Cleaner
SE 575 cams
XR crank
Energy One clutch
07+oil pump
Patriot Defender
TC88A with custom mapping
Old 21st May 2017
Green hornet's Avatar
Green hornet Green hornet is offline
Sportster/Buell Model: Sportster 72
Other Motorcycle Model: Honda CBR 1000RR DragBike
Green hornet has disabled reputation
Originally Posted by Rob S View Post
JAK, I added H-D's Comfort Flex shocks to my '13 Iron and immediately saw the need for a longer side stand. No, the bike wasn't going to fall over, but it had a noticeable lean. That got worse after I added the 2013 Roadster damper tubes to the forks--now it did look like the bike would fall over when on the side stand. I experimented with adding a block of wood of the bottom of the side stand and got the lean angle back to where I thought it belonged. I then had a welding shop make me an aluminum version of that wood block which I bolted on. That certainly looked better than the wood block, but another problem presented itself as the aluminum would really stick to the pavement as the bike settled onto its stand and would leave a smear of aluminum on the pavement. My driveway was getting aluminized and the side stand was getting shorter with the wear.
Finally, I took a chance on what I knew was a longer stand, one from an XR1200x. It's a part number 50124-09BHP. It bolted right on with no problems whatsoever and took care of the lean problem. List price was $115.31, the dealer gives a 15% discount so I paid $98 for it. Still pricey, but looks good and does the job.
Rob S
Those are the shocks I put on my 13 72. Those stock shorties were killing my back, and the Comfort Flex shocks are perfect. I'll have to look into that part number for the stand.
Old 23rd May 2017
Rob S's Avatar
Rob S Rob S is offline
Sportster/Buell Model: XL883N Iron
Rob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to allRob S is a name known to all
Originally Posted by jzink0883 View Post
Rob S,
Over the years, I've done a many demo rides on Irons and Forty-Eights. The stock 11.0" shocks felt like struts. My being 5'9" and 225# didn't help.
Questions:
- Were the Comfort Flex shocks a significant improvement?
- What do you weigh?
Jzink, while the Comfort Flex shocks made the bike tolerable, I don't feel they are the answer. I believe it would have been better to put the money towards a better after market shock. I'm heading in that direction right now and I'm looking seriously at Hagon shocks.
I weigh in at 190 lbs and am 6 ft tall.
Old 23rd May 2017
spacetiger's Avatar
spacetiger spacetiger is offline
Sportster/Buell Year: 2014
Other Motorcycle Model: 6 others
spacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant futurespacetiger has a brilliant future
Go with the longest Ohlins Rob
7 Active Bikes, not one stock...
Old 9th November 2017
shanneba shanneba is offline
Just to update this thread-
I contacted my local dealer and asked about the rear shock length -.
They said the center to center length is 340mm, or 13.39”
The travel length is 92mm, or 3.62”
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
jstoll's Avatar
so ... its been a while and reading through this I see I hijacked this thread over a kickstand :-) found a roadster stand and its great BTW... has anyone tried the SE fork setup yet? Im running intiminators on the front and when I dropped them in found that my fork tubes were straitened at some point.... anyway Im considering buying this fork setup so I can have fresh strait fork tubes and better dampening?
take care
JAK
