0 Remember these?
0 Buell Blast headlight compatibility
0 Coil Resistance Question
0 900cc Cylinders
Last Post: Nitro57xl
0 wavers
0 Rear wheel alignment
Last Post: v3ko123
0 Hagerty Insurance
Last Post: Popgadget
Last Post: Hornsmith
0 Basket case
Last Post: bill smith
Last Post: groovemeisterus
0 1968 xlch
0 Old school cool rigid struts pictures thread
Last Post: FiftySixer
0 Cv carb jetting
0 HELP Identify These Headers Please
0 Mikuni carb
Last Post: 1Scooter
0 Member "Wedge" Heads for 1275 Conversion
0 Nothing to See/Hear
Last Post: Tater66
0 tachometer on 2012 Custom
0 Help identifying brakes
Last Post: jharback
0 Boring intro
Last Post: jharback
MAJBJD (77), Jt1200r (67), 3sporty53, 69camfrk (55), nooz (46), rixta (45), saltman241 (42), Jhard206 (34), Screamin' 07 XL (34)
Old 4th June 2020
Oldmxdog61u Oldmxdog61u is offline
Sportster/Buell Model: Xlch
Sportster/Buell Year: 69
Oldmxdog61u is an unknown quantity at this point
Default Laughing shotgun pipes...Kickstarter hits pipe
68 hardtail ironhead magneto kickstart only. Pipes interfere with Kickstarter at top of stroke. Is this a Typical fitment issue resolved how? Or do people bend them somehow? Chrome pipes.
Old 5th June 2020
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
On my 1978 I fixed a similar problem by shimming the kick lever out a little with a thick [1/8" ?] washer. I have also found from time to time the pipe installation can be manipulated a bit - but you have to be careful to not introduce a leak at the head.
Can you post a pic of the problem area?
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 5th June 2020
cazz1000 cazz1000 is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1983
+1 mick,, on both,,, the pipe and the kicker.... sometimes it, s tite rope
Old 5th June 2020
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to behold
Fixes depend a lot on how far the lever needs to move to clear the pipes. I had this issue on both of my Ironheads that originally had the folding kicker introduced in 1977. I wanted traditional kick levers and had to grind a relief on the chrome kicker. I found a stainless steel kick lever on Ebay and used a torch to heat, bend and polish it so it clears.
Eric
Old 5th June 2020
Eric
That makes sense. I have jiggled, torqued and tried to see how I can get these paugho shotgun upswept pipes not to hit the kick starter with no luck. I wasn’t approaching this right. Set the pipes in place, then modify the kick lever. Presto!
Old 6th June 2020
Think I got it. Will still buy another kick, heat and bend a wee bit just to give a bit more clearance. The rear jug connection is still a little off, but no leaks I can see. Funny thing, bike runs waaaay better than with the drag pipes. When I figure out easy way I will post some pictures. Thanks.
