0 sportster revival
Last Post: 1Scooter
Last Post: Viffer
Last Post: XL Ed
0 71 XLH Value?
0 Allegheny National Park III
0 Oil coming out of top of cam cover
0 1960 XLH Stroker – a 13 year journey
0 72 ih stroker advise needed
0 ‘T’ cams, anyone familiar?
0 Evo sportster Ignition Modules
Last Post: Stojan85
0 Buell interview.
0 Sportster Tracker Wheel and Tire Questions
Last Post: The Doctor71
Last Post: jeffro57
0 No start after ultima ignition, thoughts?
Last Post: 83XLX
0 60’s XLCH front tyre
Last Post: 83XLX
0 Tuning a keihin butterfly
Last Post: 83XLX
0 '74 Front Brake Caliper leaking
Last Post: dtwaddell42
Mr. Lynn (75), dentat2 (51), OWNED13 (48), knolan.smith (43), Malicious44 (36)
  #81
Old 9th December 2012
Sportster/Buell Year #2: '03
they've been carving notches in them for,year's. old trick.some compression loss would be expected. but a,new piston,you wouldn't have any loss.
hugie03flhr hugie03flhr is offline
Sportster/Buell Model: Buell M2
hugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enoughhugie03flhr will become famous soon enough
just compession,would apply to a,flat topped piston. the wedge shape of the piston dome should have a,squish effect forcing the fuel/air mixture toward's the center of the dome,[flat area],like hugie stated.
If you can get the piston close enough .030 to the head? I wonder where the compression would be? Also how much cam timing overlap is in these ironheads? I would hate to see the carnage of the piston hitting the valve in theses engines!!! It would probably crack the jug right off...LOL
Carving a notch in the piston sounds risky? Do you do it on cast or forged only?
i,haven't done it personally. there recently was a,piston pic that had it done. mrmom9r,said he sold the piston's,to someone in europe i,believe. he would know the answer.
bobber58 bobber58 is offline
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
You can't squish the charge towards the center of the piston because the dome is there.
Old 10th December 2012
xlproject's Avatar
xlproject xlproject is offline
xlproject is an unknown quantity at this point
Default head casting
here is a notched piston...
CHOPTOP37 CHOPTOP37 is offline
Sportster/Buell Model: XLC
Sportster/Buell Year: 1972
CHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of lightCHOPTOP37 is a glorious beacon of light
forged only... i wouldnt do a cast piston and most arent thick enough any way. who made those above?
Old 21st September 2021
73HEAD 73HEAD is offline
Sportster/Buell Year: 1973
73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future73HEAD has a brilliant future
Thumbs down tincan ha ha
Originally Posted by DR DICK View Post
precisely. reducing the volume of the head side of chamber and shoving a piston with less protrusion in it should allow a quicker and higher pressure build after the spark.
(sounds like fittin evo sportster heads on shorter custom barrels and using the shorter evo rods in order to keep motor height from growing too much).
as does
increasing the swept volume under the orig chamber.
plus you get more stuff to burn in the deal. its win/win with more inches.
reguarding the 'why dont i just do evo' statement'.
because your tincover mag fired chromosome wont be satified.
thats just silly talk.
Don't mess with the piston dome, dual plug it and smile.
Old 22nd September 2021
Ferrous Head's Avatar
Blind Owl
Sportster/Buell Year #2: 1966
I'm with Rick on that.
Piston to head height I use 0.040 as a minimum. 60 over the valves.
