Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
3 Shaky Dave Recovery
Last Post: Yakcm2
0 Glyptal?
0 Photo bucket
Last Post: duffy
0 TC88A update ?
0 Too HOT to ride?
Last Post: savagegarden
0 Long intake
0 External breathing systems
0 no spark
Last Post: harley in fl
0 Options for SE a/c cover
Last Post: Doc45
0 Idle / transfer ports Q
0 WTB parts for a '96
Last Post: slamtry
Last Post: Roane
0 Vote for your favorite Babe Jump Babe.....
0 new air cleaner
Last Post: stikflote
0 Head work
Last Post: ericfreeman
Old 7th March 2015
tennmoto's Avatar
tennmoto tennmoto is offline
Sportster/Buell Model: Xl1200R
Sportster/Buell Year: 06
Other Motorcycle Model: 2014Triumph scrambler
tennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud oftennmoto has much to be proud of
Default 05 1200r
I'm doing my research on the best stage one set up for my Roadster
So please if you did a good one on your carb roadster please share.
Thanx
Old 7th March 2015
rocketmangb's Avatar
Daytona TC88A Ignition with a custom map
Pipes
Air Hammer or Hurricane flow air cleaner
Whats on your mind ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 7th March 2015
BigJoesepy BigJoesepy is offline
BigJoesepy is an unknown quantity at this point
My XL1200R has DK Customs ac, with a cv upgrade kit, and flows freely with Vance & Hines straight shot slip ons!!!
Old 8th March 2015
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
It's F-A-T.
Old 9th March 2015
tennmoto's Avatar
Default Thanx
I'm getting Buzz Buzzeli,s book on sportster performance work
I have read a lot in forum too, what I,m after is just more torque or power at lower end.
Old 9th March 2015
Buzz's book is pretty old now
Old 9th March 2015
Ireeman's Avatar
Asgardian
Sacrilege!
Old 9th March 2015
I have read it Twice !
Old 9th March 2015
mick42's Avatar
mick42 mick42 is offline
Sportster/Buell Model: 1200Roadster
Other Motorcycle Model: BMW K1600GT
mick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond reputemick42 has a reputation beyond repute
Paying taxes on a 05 Roadster never ends.
* ENGINE: 2005 XL1200Roadster
* LOWER END: Buell XB FlyWheel
* CYLINDERS: Stock bored to 1212cc
* CAMS: Hammer 560
* PISTONS: Wisco XB Domed
* HEADS: 04XL/XB with NRHS Stage 2 Lite and R&R Cycles modified intakes.
* CARBURATION: Mikuni 42 with 170 main
* PETCOCK: Pingel
* INTAKE: NRHS Porting
* AIR FILTER: R&R Cycles OverFlow for Mikuni42
* EXHAUST: D&D BobCat
* IGNITION: Daytona Twin Tech 1005(Nose Cone) running R&R map
* COILS: Daytona Tech High OutPut Single Fire
* ELECTRICAL: Cycle Electric 3-Phase
* LIGHTS: LED's on everything
* CLUTCH: Barnnet with extra plate
* REV LIMITER: 7200 RPM
* BRAKES: Front dual V-Rod caliper with floating rotors. Rear stock
* TIRES: Michelin CommanderII
[/QUOTE]
Old 9th March 2015
tennmoto's Avatar
What is CV upgrade kit and where did you get it
