0 Ground Up Beginner Build
0 Difference in Clutch Levers 45356-07 vs kit 44992-07
0 Coil polarity
Last Post: davesz1r
0 Rubber mount gas tank part
Last Post: awright2009
0 Sportster Fork Upgrade
Last Post: PetesPonies
Last Post: fafcpa
Last Post: Medyo Bastos
Last Post: smilinbrad
0 Top end failure
Last Post: Mission1
0 1998 883 spits and sputters at around 3000 rpm
Last Post: Tommr
0 clutch issue
Last Post: zack2267
Last Post: Billy1200
0 HD Museum Video - 1968 IH Dragster by Tom Reiser
Last Post: thefrenchowl
Last Post: Pagey
0 Valve keepers won't come out
Last Post: LLOYD883
0 Turtle tank on '79 frame
Last Post: brianbbs67
0 Chinese S&S carbs
0 2009 883
0 "S" model specific Q&A
0 old style fender skirted
Old 2nd June 2020
Greasyman Greasyman is offline
Sportster/Buell Year: 1974
Greasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really niceGreasyman is just really nice
Default Stock (?) 1974 cobra style seat won't fit.
My bike had no seat when I bought it, so I bought what was supposed to be an original stock cobra style seat. I don't know how the seat is supposed to fit exactly.
The side brackets line up with the bolts right behind the shocks.
Problem is, the space between brackets is too wide or too narrow to fit in any obvious spot. Too narrow to fit the width of the frame, too wide to fit the fender, and so on. The closest would be between the frame and the chrome fender bracket, but they are about an inch too narrow for that and that also doesn't look like quite the right spot anyway.
Where do they go, or do I have the wrong seat? And I'm pretty sure the front mount is attached right, with that little clip on the bolt just behind the tank.
Old 2nd June 2020
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Model #2: IronHead XLH
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
There no side brackets on an OEM Cobra seat, it just clips on the front and has one center bolt through the top of the fender...
Photos?
Patrick
Flat Head Forever
Old 2nd June 2020
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Pictures always help.
Stock sucks.
Traveled to
Old 2nd June 2020
1Scooter 1Scooter is offline
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
Sounds like you got an Ebay/Amazon universal seat. Not made to fit anything HD. Think outside of the box. Take a few photos and post them here of the seat and the front seat mount on the frame. If we see what ya got, maybe be more help for ya.
Old 2nd June 2020
It was this. I don't remember that sentence about "for choppers and trikes" when I bought it a few months ago. I probably wouldn't have bought it because my bike is stock. https://www.bmikarts.com/Selle-Giuli...ck_p_5188.html
Old 2nd June 2020
harley506d's Avatar
Sportster/Buell Model: 1200c
Could you take the cover and foam off, grind the brackets off and re weld them where they would fit your mounts?
Old 2nd June 2020
I'll probably do something like that. It looks like the seat is shaped right to look pretty good once I get it on there.
Old 3rd June 2020
That's what I thought it was. EASY FIX. Cut off the useless middle bracket and clean it up. Front mount should work OK. Place seat on the bike and mark the rear mounting hole from under the fender. Then ya need to drill n tap the hole for a 1/4-20 bolt. Add a short 1/4-20 bolt and lock washer.
Old 4th June 2020
Parker 1000 Parker 1000 is offline
Sportster/Buell Model: Xlh/Xlch
Sportster/Buell Year: 1976
Parker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to beholdParker 1000 is a splendid one to behold
You are always better off with stock Harley Davidson parts for proper fit.
