0 Sundowner seat positioning
0 Looking at a 1200S
0 Have my cake and eat it too? 1275 + 570s + CVJ
0 Sparkplugs & Sparkplug Wires
Last Post: Scuba10jdl
0 My 1250 to 1275 build
0 Splitting IH flywheels
0 Opinions - Spring plate REPLACE or REMOVE ???
Last Post: Tincan
0 Need help with S&S GB carb
Last Post: Ted Town
0 Lifting a low
Last Post: rocketnorton
0 after conversions, do have oil consumption problems?
Last Post: xllent01
0 Zenith Bendix check valve
Last Post: Kingrabbit
0 Skillz
0 Andrews PB+
Last Post: Nitro57xl
0 Best seat for long rides
Last Post: jzink0883
ziggyhd1 (61), MikeDelta (61), greven (59), bliynd (34)
Truckedup Truckedup is offline
Sportster/Buell Model: 883
Truckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of light
Default Clutch cable oil leak
I recently replaced the clutch cable on an 2001.....All was fine for a few hundred miles but now it leaks oil where the rubber outer cover is crimped into the fitting screwed into the case...Oil runs down the cable a bit and leaves puddle...With the usual "Harleys leak oil" comments...I cleaned it off and ran a bead of RTV...It's ok but will probably start leaking again...The cable was installed properly and not "man handled"...
It's a Drag Specialities branded cable...Are some cables better than others at not leaking or is this just bad luck?
650 Triumph LSR modified production pushrod 133.1 mph....
rejeanprimeau's Avatar
Did you install the O ring before screwing the new cable ?
sportyone's Avatar
sportyone sportyone is offline
Sportster/Buell Model: XL 883
Sportster/Buell Model #2: XL 1200 (totaled)
Sportster/Buell Year #2: 1994
sportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud ofsportyone has much to be proud of
my 2003 did that for a while a few years ago...if I remember correctly I took the cover off and the outer cable needed to be "screwed" back into the fitting that goes into the primary.
I may have added some sealant on that connection... but I think mostly the outer cable sheath had moved away from being imbedded into metal fitting.
I was sure my cable was shot but was relieved it was probably caused from being "unscrewed" from doing regular oil changes and clutch adjustments.
Not a drop since,
"No one goes there anymore cause it's too crowded" Yogi Berra
Not a drop since,
Yes, it's not leaking where the fitting screws into primary cover...I'll try what you say, thanks
juzyHD's Avatar
juzyHD juzyHD is offline
Bike Builder
Sportster/Buell Model: sportster 1200
Sportster/Buell Year: 1986
juzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond reputejuzyHD has a reputation beyond repute
If it leaks where the "rubbered" part of the sleeve goes into the metal one, you can solve it with one of those "self volcaniseing tape".
Lone Rider's Avatar
Sportster/Buell Model: 1200
You wouldn't by chance have over filled the primary, maybe? Just saying.
One quart of oil in the primary....I thought the end fitting was crimped but it does screw off, but it was not loose....I put sealer on the sheath and screwed it in tight...The sheath got marked up a bit but not torn screwing the fitting off and on..I had a tight fitting piece of hose and more sealer that extends over part of the fitting and sheath.. I believe it's a solid hillbilly repair. Thanks guys
