0 900cc Cylinders
Last Post: spuggy
0 Kinda of a Dumb Question on Top End Build coming up
Last Post: seajay
0 wavers
0 Member "Wedge" Heads for 1275 Conversion
0 1275 Kit and Krome Werks Headers?
0 Rear wheel alignment
Last Post: v3ko123
0 Range With EFI 4.5 Gal Tank
Last Post: jzink0883
0 Speedometer Replacement - 2011 xl1200cp - how to remove
Last Post: FiftySixer
0 Hagerty Insurance
Last Post: Akdawg
Last Post: Slytat
0 CV-40 for 88’ 883 Still leaks overflow/rebuilt
Last Post: Mission1
0 tachometer on 2012 Custom
Last Post: The Doctor71
0 Early Sportster Shock Absorber Disassembly
Last Post: Heff
0 New from Michigan
Last Post: 1skullster1
0 Fuel Sputter & Much More
0 Another Ohio Meet & Eat?
0 low rpm problem
Desertfox (70), gd714 (60), insalltm (57), seagullplayer (55), ac_tx, jon686 (49), NineSixteen (45), dstroy12 (38)
1250 kit, largest carb
  #41
davesz1r's Avatar
davesz1r davesz1r is offline
Sportster/Buell Model: xlh 883 hugger
Other Motorcycle Model: kz1000 z1r
Other Motorcycle Year: 1978
davesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to beholddavesz1r is a splendid one to behold
Definitely not me. Only my sportster at fontana.
1275 cc 10.54:1 cr se heads .560 cams hsr42 dyna 2000p patriot defender 11.63@ 115 1/4
Bryan1976's Avatar
Bryan1976 Bryan1976 is offline
Sportster/Buell Model: 1275 Sportster
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 1998
Bryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond reputeBryan1976 has a reputation beyond repute
Currently both of my bikes are set at 7000 (I think I bumped the Mule up to that). I never intentionally run up in that range though. Most of the time I am below 6400 (the tune a sporty plays at around 6400 is a symphony), but nothing pisses me off more than bumping off the rev limit when I need to get around some asshole before another dick head can try to occupy the same space I am residing in so having the limit at 7000 is necessary.
It's like Indian Larry once said, I like to know I can get out of trouble faster than I got into it. I met him once, he was quite a character and he built bikes that were rideable.
It's actually my current build that will be running the 45, George's has the 48 on it right now. Basically the Pig will be very similar to the Queen with the exception of the carb, I think also the cams will be different, I am staying with dual pipes (either the Python's or Cycle Shacks) and mine will be 1275 since that's now available. Overall, I expect we will get some good data when we compare the dyno results. I'm sure we will see the pipes on the dyno, but I will not put a two into one on the bike even the duals cost 10 HP.
And yeah. I'm certain to enjoy it. How can anyone go wrong with Hammer parts, George's calculations, my blueprinting and the team we have right here to put it together?
We have a good group here, and I can't wait for the day we get going on this. Working with these guys is as much fun as riding, and aside from helping others I expect this to be my last personal build.
If I can help in any way let me know. I have some parts just taking up space and I don't think we are that far apart.
Blue collar knuckle buster. Some call me slow Stroh. The people I work with call me G.S.D.S. They say if you want it done right , you better send G.S.D.S
wedge's Avatar
wedge wedge is offline
Thanks Bryan. We will see where it goes, but I think most if not all of the parts are accounted for. The only hold up right now is waiting for the heads jugs and pistons to come back from Hammer. Once we get those and George cc's the heads and pistons we will know what cams are going into it.
After tear down we will see if it needs a crank. George has a Buel crank on the shelf if it comes to that. I'm riding that bike today, and it feels good as always, I just get concerned with all the "harley noises" it makes.
sportsterdoc's Avatar
...And yeah. I'm certain to enjoy it. How can anyone go wrong with Hammer parts, George's calculations, my blueprinting and the team we have right here to put it together?
I don't check the forum too often. Between Sportsterpedia (thank you Ken & Hippysmack) and IXL2Relax's prompt replies, there not much with which I can be of help. So, when you get it going, send me an email or text, if you still have my contact info.
Do you realize that it has been 7 years since meeting up in Victorville! That was 5 M/C and a Y tryke ago. Be safe on those crazy SoCal freeways.
wedge's Avatar
You are welcome to drop in for the build of course, I know George would be happy to meet you. I will also let you know when it's up and running. Heck, if you like I will find time to ride out to Arizona so you can take it for a ride. I'm sure it will either put a smile on your face or kill you with a smile on your face. That's the way I am looking at it too.
Default Meet up
Been trying to get out that way for a lotta years now, have made it into northern Californica but time constraints,(that and a tore up shoulder awaiting surgery for a year), made it not happen. Now the couple trips to Lake Havasu were the better choice as your state is no way as wide as it is long. That being said I was close to Sportsterdoc but it still never worked out.
One day for sure, just need the planets to align!
Retired Feb 2017 (age 70). Company closed May 2017.
Mom passed away (91) Oct 2017 and Dad Mar 2018 (91).
My last trip to SoCal was Apr 2018.
Not expecting to return in the foreseeable future, but invitation appreciated.
Hope George is getting good use of Cosmo Kramer's schematics. I mailed them to him and did not get a chance to meet him.
But do want to know about your build.
Been trying to get out that way for a lotta years now, have made it into northern Californica but time constraints, (that and a tore up shoulder awaiting surgery for a year), made it not happen. Now the couple trips to Lake Havasu were the better choice as your state is no way as wide as it is long. That being said I was close to Sportsterdoc but it still never worked out.
Expect to take the Ryker to central Arizona some time in September. Looking forward to taking it on 89A over Mingus Mountain from Prescott to Clarkdale, via Jerome.
Let me know next time you head west.
wedge's Avatar
Let me know too. If work allows, I will run out to Arizona to meet up with you guys. Maybe I can get a couple of others to join in? Hard to say, we all like to work on the bikes around here, but as far as riding goes, we are all a bunch of loners. Actually I may be the worst in that regard. Nothing I like better than grinding out miles while residing inside my own head.
Default Miles and miles
I’m with you on that Pete, and that Arizonia meet up could develope into a “West Coast Meet n Greet”? My friends are selling the house in Lake Havasu and probably moving back to the Tennessee area, could be I’ll be needed to help with this move as well.
