0 Show me your non-stock breather systems
Last Post: ken883/1200
0 Never seen this before...
Last Post: dieselvette
0 Unknown HD Saddlebags (need info)
Last Post: mwXL 2006
0 sportster chin spoiler, yay or nay?
Last Post: Ghostdog
0 Air Cleaner Porn!!!
Last Post: Scott
Last Post: Tonyb65
0 Plastic welders?
Last Post: spamer80
Last Post: Hornsmith
0 Seeley Ironhead race bike
0 Movotor Smoked Tail Light and Turn Signal
Last Post: xElvis
0 Introduction
0 Cleaning Fuel Injectors
0 Hello from Minnesota
0 Vibration supposed to be this bad?
0 2011 Nightster--First Impressions
0 Splitting IH flywheels
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sglock45
0 Shifter Went Limp
0 Round Air Cleaner Poll
Last Post: Hellbent_4
0 Stock vs. Modified
Last Post: Monte03
0 dual carb heads on ebay
Last Post: Scott
Default Glutten for punishment sportster cams it ain't
this is a 1900 session mantel clock that has been in our family since new. i picked it up with intent to repair. i know why it stopped working, two hair springs that controlled the gong and chime. all the bushings and shaft holes are good, no reason to allow shaft/gear bind.
can send it off for 200 dollars but can take a year to get back so i was wondering if there are any clock smiths out there in forum land.
sportster cams it is not but i sure am going to try and get it going.
thanks, buster
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Not a CLOCK guru. But interested non the less because Mom shipped me
She had it rebuilt before the shipper destroyed it en route to me. Broken glass. The whole works. I know of a place in
http://www.clocksandmore.net/index.html
But I am totally ignorant when it comes to antique clocks.
Traveled to
Skwerly's Avatar
Skwerly Skwerly is offline
Sportster/Buell Model: Unsure
Sportster/Buell Year: 1982
Skwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud ofSkwerly has much to be proud of
I have a buddy knows about this stuff. I'll link him here.
Skwerly's Avatar
ok, linked him and he said it's not his wheelhouse.
ken883/1200 ken883/1200 is online now
Sportster/Buell Model #2: Sportster 883/1200
Sportster/Buell Year #2: 1988
Other Motorcycle Model: Yamaha XS 650
Other Motorcycle Year: 1982
ken883/1200 is an unknown quantity at this point
I know it's not what you are asking for but did a search on line and seems there are many used mechanisms available relatively cheap:
https://www.ebay.com/i/263901606121?...SABEgKtPfD_BwE
Maybe 50 years ago I did manage to disassemble on of those and get it back to working condition. The one I worked on had as the only real problem the two main springs were all gummed up and just would not slide against them selves. Just unwound them and cleaned and lightly lubed them reassembled and it actually worked.
I bet if you take your time and dry fit one gear at a time and take pictures and make notes you can figure it out!
thanks for the replies. i have looked at some sites and ebay one of them but the issue here is i probably will get one worst than i have. i talked to one clock smith and he is booked to next year, apparently there is good money in it and really 200 dollars isn't bad, just the wait time.
one of the biggest issues is pin wear and lantern gear wear which this clock does not have. it sat in an old farm house in illinois for decades. before i torn it down, there was two hair springs, one for gong and one for chime that were snafu'd, that will be the trick, as probably will have to make them. since the sound side is syn'd to the time side and it could work, the movement stopped.
i will give the guy a call to see if he can help a little faster than the on in pa. there are some interesting video's on this type of work.
Yakcm2's Avatar
Yakcm2 Yakcm2 is offline
Sportster/Buell Model: XLS 1000 Roadster
Yakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond reputeYakcm2 has a reputation beyond repute
Wife an I have a local shop working on grampa’s Grandfather clock (clean,lube an calibrate.) $250. + tax and a 3 to 4 month turn around here in Federal Way, Wa.
I think this is one of those cases where the art-form of clock repair is a “dying” one...not a lot of ol’timers left that have the skill, it’s a shame.
and that's my 2cents worth...
You work on the tiniest, coolest stuff I've ever seen.
I bet you could have it going in less time than that.
Reading this thread has me thinking about a 1950's vintage Cuckoo-Clock sitting a a shelf in the basement. It was damaged probably some time in mid to late 1950's. My older brother made the mistake of pulling down on one of the weights and it broke what I would call the ratchet mechanism that is used to "rewind" the clock.
Back in the 1960's I did take it apart to find the problem but could not see a way to repair the broken spring that ratchets when the correct side of the chain is pulled. So I reassembled it after having no luck finding anybody who could supply parts.
Now with the availability of the inernet I going to do some searching and see if I have better luck. I already found one place that may have the part I need and sent an email to them. If the part is the correct for this make of clock I'll give it another try! And the part is listed for only $8.95!
best of luck to bustert!
Just a thought for bustert, you say the ones on ebay may be worn in the shafts and bushings but you might get lucky and find one that has the hair springs that your clock needs. $35.00 would not be too bd a price for a parts machine to rob parts from!
