Last Post: Bone
0 Small nail in tire?? plug or replace
Last Post: jimmyess333
Last Post: toe
0 1200s mid throttle stumble
0 I love my Mikuni VM38-9 because ...
Last Post: Serious Blac
Last Post: moparnut72
0 Sportster tachometer wiring question
Last Post: sleighcrane
0 Why do sportsters look small?
Last Post: kopbilly1
0 First Harley(has issues) - 95 sportster 1200
Last Post: 95sporty1200
0 Need some help chasing a tick
0 Topend problem
Last Post: dodgetrucken
0 '71 XLCH starting issues, any ideas?
0 A Day in the Life...
Last Post: gravydog
5 Eye Protection When Riding?
0 Anyone try the new Conti tour tires
Last Post: Wyo George
0 What riding gear do you have/wear in good and/or poor weather?
Last Post: TheDinglepuss
0 Another ironhead roadracer
Last Post: Scott
0 Helmet poll
0 Magnaflow F-Bomb on a Rigid?
0 S&S pushrod adjustment
Last Post: T_worth
0 New problem with 1200s (Rev Limiter)
Last Post: ftwflh
0 Suzuki Lights On 883
9 Aftermarket Petcocks
Last Post: ezmerf
doughboy (65), tinman (63), mofo (56), JAFI (55), Topgun (53), Hogwylde (53), Pay Toilet (52), grwhite038 (50), JWG883 (49), sorryifitburns (45), Leibniz (43), higgins14 (41)
jordan1200's Avatar
Default Cylinders and static compression checked. Advise?
Ok I did a static compression test last night and got 170 psi per cylinder (engine cold).
Seems a bit low doesn't it. Before the teardown and piston replacement I had about 180 psi.
I have about 1200 km. on the top end. I did a check at about 800 km and I got 180 psi.. (cold engine).
Now I took my telescopic camera into the combustion chamber and the front cylinder looks pretty clean still. The rear has me concerned. See pictures
Front cylinder first picture
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
well if you just replace parts, it might take awhile to seat in. so a ?
did you do a bore? or just a hone?
did you check for taper?
jordan1200's Avatar
Bored 0.010" over with factory Buell pistons
jordan1200's Avatar
Any thoughts on the pictures?
had to say over the net
but
hd cyl's do not run the same, look at how they are fueled
i run diff heat ranges to even out the two plug wise
