Last Post: Bone
0 Small nail in tire?? plug or replace
Last Post: jimmyess333
Last Post: toe
0 1200s mid throttle stumble
0 I love my Mikuni VM38-9 because ...
Last Post: Serious Blac
Last Post: moparnut72
0 Sportster tachometer wiring question
Last Post: sleighcrane
0 Why do sportsters look small?
Last Post: kopbilly1
0 First Harley(has issues) - 95 sportster 1200
Last Post: 95sporty1200
0 Need some help chasing a tick
0 Topend problem
Last Post: dodgetrucken
0 '71 XLCH starting issues, any ideas?
0 A Day in the Life...
Last Post: gravydog
5 Eye Protection When Riding?
0 Anyone try the new Conti tour tires
Last Post: Wyo George
0 What riding gear do you have/wear in good and/or poor weather?
Last Post: TheDinglepuss
0 Another ironhead roadracer
Last Post: Scott
0 Helmet poll
0 Magnaflow F-Bomb on a Rigid?
0 S&S pushrod adjustment
Last Post: T_worth
0 New problem with 1200s (Rev Limiter)
Last Post: ftwflh
0 Suzuki Lights On 883
9 Aftermarket Petcocks
Last Post: ezmerf
doughboy (65), tinman (63), mofo (56), JAFI (55), Topgun (53), Hogwylde (53), Pay Toilet (52), grwhite038 (50), JWG883 (49), sorryifitburns (45), Leibniz (43), higgins14 (41)
  #151
Old 6 Days Ago
Rolli Rolli is offline
Sportster/Buell Model: xl1000
Sportster/Buell Year: 81
Other Motorcycle Model: Honda CB750 four
Other Motorcycle Year: 71
Rolli is an unknown quantity at this point
A few of us on this forum have run a vent line from the 6:00 o'clock position for years now. In our experience it does make the engine run noticeably more freely. I run mine all the way back to the rear muffler bracket. I get a few drips out of it after a "spirited" ride
And yes, it does function from the reed/check valve assembly...
I my opinion, the original breater is piece of crap. Also if you renew it.
Since two years i run both breathers, the OEM and my special one mentioned above.
It drains much more mayo out of the engine then the original one.
You will notice this only riding in temperatures below 15°C as moisture in the air increases.
Old 6 Days Ago
blk80bike blk80bike is offline
blk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enoughblk80bike will become famous soon enough
I was pretty sure that the lower port also operates through the one way valve but I sometimes find myself overthinking things. I'm going to plumb it in tomorrow and run it the same way you described. I'm thinking a few zip ties will do the trick. I don't have a lot of oil making its way into the ham can anymore since I did the spray with WD40... but I'm hoping that this will eliminate the majority of the oil that finds its way up there.
1980 Sportster XLH 1000
Old 5 Days Ago
By opening the lower 6 oclock position you are defeating the oil drain feature built into the cover valve.
You will find a very small hole that allows any oil that gets by the valve to drain back into the motor. When you connect a hose to the bottom fitting the oil will run out the hose instead of draining back into the motor.
Old 5 Days Ago
That's pretty much what I was thinking. That tiny hole is supposed to allow accumulated oil to drain back into the motor but it doesn't seem to work nearly as well as it should.
Guess I'll see what happens...I just plumbed the brass fitting and vapor hose.
Old 5 Days Ago
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
... When you connect a hose to the bottom fitting the oil will run out the hose instead of draining back into the motor.
... I run mine all the way back to the rear muffler bracket. I get a few drips out of it after a "spirited" ride ...
Only a few drips, and only under a limited circumstance.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 2 Days Ago
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
I've been running the 2-hose setup on mine for years. Yes, a few drips come out of the hose if the bike is ridden hard, but the engine revs quicker and there's no oil blowing on the side of the bike any more.
