0 6 speed
0 New member
0 More oil return questions
Last Post: Scott
0 who rides with a Flyscreen (or similar) AND an open face helmet?
0 883 cc >> 1200 cc big bore conversion
Last Post: lovevoodoo
0 Mac exhaust
Last Post: Maxdog2
Last Post: HDCUSTMBUILD
0 Brake pedal adjustment on 09 Custom
0 Tools
7 Ironhead yes or no
0 SBS Project - Sportster Chop w/ Lots of Photo's
0 forged pistons?
0 Sportsterpedia Progress
0 IH rearsets and giant stud
Last Post: dewjantim
0 1250 break in map for tc88a
0 TC88A EEPROM or FLASH
3 Shaky Dave Recovery
0 Getting Hammered
Last Post: Bryan83taco
0 Power outlet
Last Post: RDHenley
Last Post: RDHenley
0 8th Air Force memorials in the UK
Cbande88 Cbande88 is offline
Sportster/Buell Model: Xl883
Cbande88 is an unknown quantity at this point
Default 2006 Sportster front fork swap issue
Hello all, I am having a slight problem. I am rebuilding my crashed 2006 Sportster 883 I recently purchased (previous owner crashed it) and I bought a second hand pair of forks and trees for it. I went to install the front end today and everything went on perfectly except 1 minor issue... The axle where it meets the pinch stay on the right side is to small and not the same size as the one from the original forks. I was wondering if anyone knew what axle I need for it? The guy who sold me the front end couldn't recall what year the forks where from (edit..it's a 2010 front end) Any help is always appreciated! Also if it matters at all, the new purchased set of forks is slightly shorter than the ones pulled off my bike. (Not a big deal as I already purchased lowering shocks for the rear) I have attached a picture. Has anyone successfully used newer year model 1" bearings and axles on 3/4 wheels? I do know the outer diameter of the newer style bearings is 51mm (same as the older style) but I'm unsure if the center spacer on later models between bearings is suitable? The new style bearings are 6mm narrower than the old style as well from what I read. Wondering if anyone knew the secret recipe for fixing my issue.
harley506d's Avatar
Sportster/Buell Model: 1200c
Have a look here......
http://sportsterpedia.com/doku.php/t...k:evo:wheels01
might help you understand what you need.
Sounds like you will need the axle with inner/outer spacers/washers and nut from a '10 model with the narrow glide forks.
Front fender/caliper mounts the same?
Your pic not showing.
The brakes mount fine and it slides in perfectly and mounts fine on the right side. Just the head of the axle is to small
harley506d's Avatar
I thought your original axle was 3/4" and the new forks are off a 2010 model with 25mm axle.
