0 1967 Harley Sprint SS250
Last Post: Tonyb65
Last Post: toe
Last Post: rubine
0 erratic Badlands indicator module
Last Post: 45Brit
0 Solenoid rebuild drained battery
Last Post: mikam123
0 Leaking Head Gasket, Loose head bolts
Last Post: Blue Scoot
0 good ride today
0 Killed 2 batteries (not ran out of juice)
0 Show me your non-stock breather systems
0 Currently in deep shift...
Last Post: shgrier
0 How the heck do you remove seat with rear wheel on
0 Oil Temp
0 Speedo ideals
Last Post: dodgetrucken
0 Glutten for punishment sportster cams it ain't
10 how low do you let it idle
5 What can cause the engine to suddenly misfire?
0 Vm38 mikuni carb
Last Post: Whitewalls
0 Use Force Sportster Exhaust
0 Deleting all switches, adding push button starter 2005 sportster
0 XR750 road bike?
Last Post: Scott
0 75 XLH Electrical problem - Accessory Circuit
Last Post: 72 Ironhead XLH
0 75 XLH battery tray bracket
Last Post: USAFpj
0 RIP Peter Fonda (02/23/1940 – 08/16/2019)
Last Post: Sprtstr1200s
0 Branch O'Keefe heads (with photos)
Folkie Folkie is offline
Default Lympstone, 23rd July 2019
Today I went on a ride to Lympstone in Devon. Lympstone is on the Exe estuary, about 2 miles North of Exmouth.
This is the route that I took:
It was a bit foggy when I started out, but that soon cleared. I went along the A/M27, A31, and A35 to Charmouth, then the A3052 to Lyme Regis. I stopped in Lyme Regis and took some pics.
Lyme Regis:
After Lyme Regis, I continued on the A3052 (which was very quiet: I had the road to myself!) to Newton Poppleford. Along the way I passed a crossroads called "Hangman's Stone"! Then B roads and minor roads to Budleigh Salterton.
Budleigh Salterton:
I left Budleigh Salterton along a road called 'Outer Ting Tong'! This was one of the roads (another being: 'Inner TIng Tong') to the Thing Tun (place where the governing assembly was held). And on to Lympstone.
Here's the last bit of the journey (about 10 miles) at a much larger scale:
I found somewhere to park the bike, and walked into the centre of the village.
First glimpse of the waterfront:
The main village street:
I had lunch in The Swan Inn.
The Swan Inn:
After lunch I thought I'd look around a bit more.
Oh, hello:
I went down to the waterfront:
On the way back I thought I'd explore some of the little alleys:
Which brought me out further along the waterfront:
Where's this go:
Oh, look:
Last glimpse of the waterfront before leaving:
This is my return route:
Here's the first part of the route, down to Exmouth and along the sea front there, at a larger scale:
On the quay at Exmouth:
The tip of Dawlich Warren Spit, seen across the River Exe:
Cockwood, across the river:
Cockwood and, to the right, Starcross:
Fish being unloaded from a fіshing bοat at the dock:
From Exmouth I went back up to Newton Poppleford; pretty much directly, not going via Budleigh Salterton this time. Then back home by the same route. There are lengthy rοadworks on the M27, from Southampton and past Portsmmouth, with a 50 mph speed limit through the rοadworks. Even when they eventually came to an end, there was pretty bad congestion anyway; traffic was often at a standstill. Consequently I was lane splitting, pretty much continously, for miles!
Total distance: 334 miles.
It was a great day: the weather was very hot and sunny, and Lympstone is lovely.
Glamazon Glamazon is online now
Senior Master Bike Builder
Sportster/Buell Model: xl883r
Sportster/Buell Year: 2014
Thanks for another great read & photos Nigel.Beautiful part of the country I must see one day
a-sad-anorak's Avatar
a-sad-anorak a-sad-anorak is offline
a-sad-anorak is an unknown quantity at this point
Lovely pictures and a good day out. I've spent many happy hours fishing for mackerel from Chesil bank. Also the quaint Wet Fish Shop down by the Cobb in Lyme Regis. Thank you.
