0 55* this morning
Last Post: sportymike02
0 carbs?
0 2007 883R From Sunny Old England!
0 starting rollers
0 KBS tank sealer
0 Better Brakes
0 Microsquirt EFI Conversion
0 82 XLH struggling for power
Last Post: BigMek
Last Post: jcro61
0 Forum member mug shots
0 Old new guy
0 77xl sportster
0 BEWARE Of SCAMMERS!
2 My 1275 Hammer Conversion..
0 "She" bolts
Last Post: denguy
0 Range With EFI 4.5 Gal Tank
Last Post: oldboy
garryd (72), Chooch (69), kicker (63), Calgaich (60), skinnyboy (58), RogerB, Tonyb65 (55), sunkenloot (45), scoobs48, zman69 (39)
Old 12th October 2020
mrbreezeet1's Avatar
mrbreezeet1 mrbreezeet1 is offline
mrbreezeet1 is on a distinguished roadmrbreezeet1 is on a distinguished road
Default 2002 1200 XLC screamin Eagle air filter
I lost the filter for my 2002 XLC 1200.
It had the stage 1 I guess it's called air filter installed on it.
It looks a lot like this filter,
But both the front and back are open.
On the one I linked to, the front is closed in.
would this one work on mine?
Everything I find seems to say 2004 and up,
As if 2002 is so outdated or something.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Edit I meant 2004 and up
I wonder if I could make this one fit?
https://www.ebay.com/itm/Harley-Davi...cAAOSw7HFfH5d0
I Found IT!
Thanks For Reading though!
XL1275 XL1275 is offline
XL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant futureXL1275 has a brilliant future
Use blue locktite. My cover and filter on my round cleaner came loose. Luckily I was back in the neighborhood coming home from a ride and found them. I knew better than to not install with thread locker.
Old 26th October 2020
lespaul6's Avatar
lespaul6 lespaul6 is offline
Sportster/Buell Model #2: 2002 XL 1200C
Sportster/Buell Year #2: 2000
Other Motorcycle Model: XL1200C
lespaul6 has disabled reputation
You're lucky.. you will not find one of those filters unless you don't mind a used one off Ebay- and that might be a hard find. You would have to buy a whole new K&N setup.. not cheap.
00 1200C/01 1200C/03 1200C
