0 55* this morning
Last Post: sportymike02
0 carbs?
0 2007 883R From Sunny Old England!
0 starting rollers
0 KBS tank sealer
0 Better Brakes
0 Microsquirt EFI Conversion
0 82 XLH struggling for power
Last Post: BigMek
Last Post: jcro61
0 Forum member mug shots
0 Old new guy
0 77xl sportster
0 BEWARE Of SCAMMERS!
2 My 1275 Hammer Conversion..
0 "She" bolts
Last Post: denguy
0 Range With EFI 4.5 Gal Tank
Last Post: oldboy
garryd (72), Chooch (69), kicker (63), Calgaich (60), skinnyboy (58), RogerB, Tonyb65 (55), sunkenloot (45), scoobs48, zman69 (39)
Erikdowney18 Erikdowney18 is offline
Sportster/Buell Year: 1973
Erikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really niceErikdowney18 is just really nice
Still no bueno, after taking the carb off and playing with the O-rings the bike will almost hold an idle and will just sit there and run like shit. I don’t know if it’s a vacuum issue or if maybe I burned a valve but it just can’t get going. I’m gonna see if I can grab a compression tester from work to test the barrels but somethings clearly not kosher. I’m thinking maybe change the points too? I know last time they went I had am extra set of contacts but no condenser so I only switched the contacts. Also gonna try throwing a set of rubber bands on the manifold too and see what that does. Any other areas I should circle back before I start thinking top end work?
Just figuring start stupid and get smarter
Ferrous Head's Avatar
Ferrous Head Ferrous Head is online now
Blind Owl
Sportster/Buell Year #2: 1966
I actually took some wire and ran it through all the jets
Don't do that. You will damage them. Compressed air is your friend.
Idle is controlled by a small hole partially blocked off by a tapered screw. The seat that screw goes into can be damaged simply by tightening that screw too much.
The passages inside the carb need to be clear. Given that you have a rusty tank there may well be small particles in the internal passages that feed the idle circuit.
When you just "crack" the throttle it uncovers another very small hole sitting just in front of the throttle disc. (On the venturi side of the carb) You see how small that hole is ?
The enrichner circuit also needs to be working correctly. It provides extra fuel for starting the engine but should shit off fully when released.
I have a new tool in my box that determines for me if the problem is in the carb or the ignition system so I do not have to guess at which area the problem is.
It's pretty expensive ($59 on Ebay) and a bit fiddly to use.
BUT - it does guarantee me that I'm looking at a carb problem and not an ignition system problem. Or even a compression problem.
Eliminates 2/3 rds of all problems immediately.
Blind Owl
OOOOPS !
Sorry, the price of that tool has dropped to $52.
I've used mine a couple times now and it works like a charm.
https://www.ebay.com/itm/New-Carbure...ampid%3APL_CLK
