Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > SuperBrace
2 My 1275 Hammer Conversion..
0 su carb question
0 Performance valves and springs
0 In case you have not seen Harley-Davidson's New Business Plan-
Last Post: fafcpa
0 Clunking into 1st after Clutch is engaged and shifter is pressed
Last Post: DitchTBHSMM
0 New to the Chopper Lyfe
0 *DK Custom - Limited Time Sweetheart Deals - Save 10% On Select Items*
Last Post: TUCCI
Last Post: brixtonanima
0 Too HOT to ride?
0 Checking slow jet is correct size
Last Post: Billy1200
0 C.O.B.B. CBD oil
Last Post: TUCCI
Last Post: SLW210
0 new to me 883
Last Post: robbie202
0 New member
Last Post: spamer80
0 Roadster CX Cafe Build
14 Mid controls??
Last Post: Nicktree1200
0 Best Street/track Camshaft for boost, help??? :)
Last Post: Jens L
0 Frame bracket
Last Post: Bwf347
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Headlight help please
Last Post: PetesPonies
Last Post: TUCCI
0 tire changer
0 Ve tables for iron 883 with 1250 conversion
Last Post: Bikeaholic
fhilliard (79), paulmo (75), Beloved (49), Mr. Cro (49), Chopper Duke (41), Danny3nose (39)
Old 28th December 2014
Sportster/Buell Year #2: 2008
Default Jabberwalky
Original post:
Originally Posted by 2011-XL1200C View Post
Superbrace for the new 48s and customs ?
Has anyone tried a Superbrace on the wider forks and 130/90 16 front tire of XLC 2011 and 48s.
Originally Posted by Rog48 View Post
Not what I said. Your post makes no sense. The question was about a fork brace for a 48, the 48 already has a beefy one so does not need one. Your response was if you swap out pretty much the whole front end then you need one...................related to the question posed.....your response makes no sense.
1. read OP
2. Sounds something like what I want to do.
3. Good day.
Last edited by Turbo Sporty 48; 28th December 2014 at 18:05.. Reason: Looking For Solutions
Rog48's Avatar
Rog48 Rog48 is offline
Sportster/Buell Model: 48
Other Motorcycle Model: Kawasaki KZ650
Other Motorcycle Year: 1977
Rog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant futureRog48 has a brilliant future
I did read the OP, thats why I commented that your post made no sense......which it doesnt. Superbrace doesnt even make one for the 48, why? BECAUSE IT DOESNT NEED ONE!
3. Better day
2011 XL1200X - 1977 KZ650 - 1982 KZ1100 - 2006 TW200 - 2009 TW200
