Last Post: mrmom9r
0 Your never too old
0 Magneto points & condenser
Last Post: Captain Johnny
0 Replace lifter(s) w/out teardown?
Last Post: hbsporty
0 72 XLCH clutch ball and ramp system
0 Xl???
Last Post: SLW210
0 AHDRA Orlando speed world??
Last Post: painterdude923
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
oldsporty1 (70), paris15 (62), thesmithiz (62), pajimmyjoe (61), chuckam (57), steve w (51), le_strike (44), Rubicon (38), r3db3ard3d (32), rortiz76 (32)
bleed, brake, brake bleed, brakes, sportster
Old 12th August 2015
PheenX PheenX is offline
Sportster/Buell Model: XL 1200 Roadster
PheenX is an unknown quantity at this point
Exclamation Rear brakes won't bleed!
I just replaced the rear brake pads on my 2004 sportster XL 1200 R and in doing so found out there was air in the brake lines. So of course I decided to bleed them.
However the whole time I was pumping the brake and then holding it, I was unable to make any fluid flow through! I was wondering if anyone had any tips/advice? Would be much appreciated thanks.
rejeanprimeau's Avatar
Removed your MC tank's cap, press the brake pedal, if you see a geyser, you 're a new member of the MC teared rubber cup club. You should have open the bleeder before pushing in the piston. Buy a kit and rebuilt the master cylinder. You need a circlip plier to do the job.
I did open the bleeder before pushing in the piston, and I see no geyser, Nothingat all is happening really. Do I just have a ton of air in the lines maybe?
Old 13th August 2015
Fill up the tank, attach your pedal to a heavy thing, open the bleeder and let gravity fill your line. Usually take an hour.
Eric Von Zipper's Avatar
Eric Von Zipper Eric Von Zipper is offline
Sportster/Buell Model: C for Chrome
Eric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant futureEric Von Zipper has a brilliant future
I drained my entire brake system, and refilled it. it was a royal pain
DaytonaSportster's Avatar
DaytonaSportster DaytonaSportster is offline
Sportster/Buell Model: XL1200c
DaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond reputeDaytonaSportster has a reputation beyond repute
You can use a vacuum to pull thru, or hang the caliper lower to let the bubble go up (helps to have the line loose too.
Last suggestion is to use a syringe and push fluid into the caliper. But this will tear the cup in the slave cylinder for sure if the stock cup.
http://xlforum.net/forums/showthread.php?t=842245
