0 Your never too old
0 Throttle side turn signal failure
0 Riding music
Last Post: sprink
0 Photos: King Peanut or Regular Peanut tank?
Last Post: drgonzo21
0 Now I did it. Feel my pain
0 Sportster drag bike
0 Fair price for used parts
0 Oil not returning to tank
0 Mikuni - hangin revs
0 100 vs 110 front tire
0 Sportsters in movies and TV
Last Post: joes95bobber
0 Xl???
Last Post: seajay
0 My '96!
Last Post: 1200CustomHD
0 Xr750
Last Post: SLW210
0 S&S Super E Carb
0 so it's officially ended
Last Post: robbie202
0 New to me '08 1200R
Last Post: PhiRR
0 TC88A update ?
Last Post: HOG63
5 Dynatek DSPT-1 ?
Last Post: HOG63
Last Post: CCC
Last Post: slojoe631
texrex (68), jjluvstoride (55), luisbmns (50), njstoehr (44), tacho75xlh (41), 80ironhead80 (31), Xttrackerr (25)
adjustment, clutch, clutch cable, clutch problems
Old 28th March 2012
stevedrum4578 stevedrum4578 is offline
Sportster/Buell Model: 883
stevedrum4578 is an unknown quantity at this point
thanks guys. i readjusted and it seems to be fine now. i will keep an eye on the bearing and the EZ clutch. I guess part of buying a used bike, is undoing what the guy before you did. huh?
Old 28th March 2012
wedge's Avatar
wedge wedge is offline
Originally Posted by ironhead1313 View Post
Hmmmm, think you got bearing issue maybe???
Likely so, but which one? Basket?
Old 28th March 2012
Desertfox's Avatar
Desertfox Desertfox is offline
Sportster/Buell Model: 2001 883 Custom
Desertfox has disabled reputation
I just replaced mine because I thought it was making a squealing sound, but it was just fine, and the squeal is still there. .
Yep, if it's squealing it's the throw out bearing. I would advise changing it very soon before you get stranded.
If you hate me, I've probably given you just cause. There, feel better?
Old 28th March 2012
wedge's Avatar
Note that I said I just replaced the throwout bearing. The one I took out looked and fealt good, and the new one is in there now and there is still the same squeal. It is intermittent, and it sounds as described earlier, like a dry bushing, chirp now and then, and then the chirp stays for a bit, then goes away, and some times it starts to squeal and it keeps squealing. I'm wondering if it may be the basket bearing? Or possibly the primary chain adjuster? Not likely the adjuster shoe though, because this has a rotating kind of squeal sound in my opinion. I get a similar squeal from my bench sander now and then, and spraying the wheel bushings gets rid of it, that's why I think it sounds like a dry bushing.
Old 1st April 2012
Cámo's Avatar
Cámo Cámo is offline
Sportster/Buell Model #2: Ironhead
Sportster/Buell Year #2: 1977
Cámo is an unknown quantity at this point
Hi guys. I'm trying to resolve my problem with '77 Iron. And you're right problem is with clutch, I know again :-) The main problem is the clutch won't disengage. I followed the steps who wrote here to this topic, but without any good results
But I tried play with adjust screw and if I pull it inwards somethings happens, the bike started to skipp front, but there's a lot of slips on clutch. So after that I tried play with cable adjuster but the result was only the engage point move up a little bit.
Before this problems I cleaned primary, adjust chain, changed inner rubber boot, and clutch plates seemed good. So, I did it together and now I'm really sad ( I found some vids on youtube and saw the big washer between primary cover and outer ramp. And on my Iron wasn't any washer before. So who thinks there's a problem? Or some another problem? I really don't know what I will do with it :-(((
Thanks for your help!!!
Old 2nd April 2012
Cámo's Avatar
Or if somebody knows the washers diameters and give me it, I!m really glad too:-) then I try to re-install primary and put this washer into primary hole....thanks!!!
Old 2nd April 2012
Desertfox's Avatar
Note that I said I just replaced the throwout bearing. The one I took out looked and fealt good, and the new one is in there now and there is still the same squeal. .
ooops my bad. However the clutch actually has two bearings. The throwout bearing and a main clutch bearing deeper down. Might want to look at that one. Try rotating the clutch shell while holding the clutch hub. If it feels rough or is binding, it needs replacing.
Old 2nd April 2012
wedge's Avatar
That is what I have been refering too as the basket bearing, and I think you are right, that may be the issue. So a good test would be to see if I can make that noise happen with the clutch pulled in standing still as I rev the engine.? I will try that.
Old 2nd April 2012
ironhead1313's Avatar
ironhead1313 ironhead1313 is offline
ironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of lightironhead1313 is a glorious beacon of light
Sorry, I've only been in one Ironhead primary/trans. It was a while back, and I don't remember much about it or what the differences were between the evo and ironhead.
Old 2nd April 2012
Possibly main shaft bearing??????
