Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
0 Plastic rocker box breather valves
0 Brand new 2020 XL1200NS
5 Cruise-Mate (Europe)
0 Down on oil
Last Post: Billy1200
0 Vintage tires
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 Remember these?
Last Post: bill smith
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
fix, help please!!!, leak, oil
Old 13th March 2014
06sportyC 06sportyC is offline
06sportyC is an unknown quantity at this point
Default Help (Oil Dripping)
Hey fellow xl forumers!
As my name suggest I have a 2006 sportster 1200C in yellow, anywho, i noticed the other day after a 50 mile ride, it was dripping dime sized amounts of oil.
The bike has 23,000 miles on it and it has never leaked a drop now it drops a few a day. IT LOOKS as if its coming from the seam split in the case (god i hope not) and collects on the cross member of the frame infront of the primary and also on the primary drain plug. It isn' from a loose main oil drain plug either.
Im thinking because it only seem apparent after the bike cools down after a ride that its a gasket? but i also see its the inner primary gasket/seal on some people bikes.
I know "its marking its territory" but seeing any fluid on ya garage floor is dis-concerning.
Any ideas what it could be? its definitely oil, not the vent for gas.
Thanks in advance help me fix my baby!!
Old 13th March 2014
rocketmangb's Avatar
Welcome aboard Sporty !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 13th March 2014
Welcome to the forum family from a swamp in Michigan. Do a thorough cleaning then spray some "Soft-n-Dry" anti perspirent around the area,(Anthony tool), run the bike and it should become obvious where it origionates from.
Old 13th March 2014
Gorgeous Bike Rocketman! Looks like mine, except i have road king shocks on mine an SEII pipes!
Thanks sportsterpaul, I will try that this weekend!
Old 23rd March 2014
I found the cause, oil drain hose was dry rotted and burst in two places. Amazingly it was only $7.11 at my local stealership.
Old 23rd March 2014
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
wow, first time I heard that one... another thing to keep an eye on.
Welcome aboard and thanks for posting your fix!
John from Windsor Ontario
'00 FXDL
Old 23rd March 2014
ChinCactus's Avatar
Glad it was a simple fix! Welcome man!
Old 23rd March 2014
Loner's Avatar
Loner Loner is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2012
Loner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant futureLoner has a brilliant future
My 1996 and 2002 both did that.
Old 23rd March 2014
HD_XL rider's Avatar
Sportster/Buell Model: XL 883
Sportster/Buell Year #2: 2008
HD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond reputeHD_XL rider has a reputation beyond repute
Glad that you were able to take care of it with an easy fix
Welcome to the forum from TN
Old 23rd March 2014
randy3934's Avatar
There's a message there, if that hose dry rotted how's the rest of your oil lines doing?.
