Last Post: darwin-t
0 Opinions
Last Post: Racepres
0 Static timing
0 Which cams ?
0 Fuel Pump Problems
Last Post: Lowe175
0 Front end restoration
Last Post: Dosmie72
0 Hello New in the Forum
0 Accelerator nozzle and idle not right
Last Post: hexnut
0 Kicker shaft question
Last Post: Captain Johnny
0 Spitfire motorcycle 2 into 1 Blaster
Last Post: Bmyers
0 The salty debate thread.
Last Post: Uberstorm
Last Post: XL1275
14 How To: View HD Part #'s 1991-2010 - All Models - With Part #'s and Exploded Views!!
Last Post: Eddie65
Last Post: MikeBel
0 Kick starter resistance
Last Post: metal88
Last Post: Proteus
0 19" Tire w/23" Overall Diameter???
0 Smacked a deer last night
cams, leak, seal, stem, valve
Old 7th May 2015
groovemeisterus's Avatar
groovemeisterus groovemeisterus is offline
Sportster/Buell Model: XL883-1200 Branch Build
groovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to beholdgroovemeisterus is a splendid one to behold
Question Conversion Causing Valve Stem Seal Leak? Picts.
After conversion... might be an on going issue, or just bad valve stem seals, or I just ride the hell out of it at high RPM... red lines 6800. A hot rodded engine usually needs rebuilt. Has happened before.
Last Dyno was bout 85T 85HP. But carb could also be jetted wrong and running really rich?
Do ya'll think these pictures show that the valve stem seals are going bad?
After engine warmed up and hot... rear cylinder exhaust sounds different than front. Front has complete spark and ignites mixture(can hear explosion), while rear exhaust note sounds like is pinging, or carbon deposits are hot enough to pre ignite the air fuel, which gives a non explosive sound as the front exhaust gives.
When gets hot as above, the idle changes. Like coming up to a stop sign, then the idle is way higher, and engine sound changes, and others ask if I have enough oil etc.
If so, any suggestions on valve stem seals that will LAST? or maybe another issue?
Any and all feedback is appreciated! d
Please don't hesitate to ask more questions to help resolve and make sure from picts and symptoms. Engine just got taken apart and can add more picts of different components.
My engine sig is listed below. Bob woods prowler cams, and branch ported heads are prob main influence for wear and tear.
Intake Valve
Piston
Combustion Chamber
883 XL Y2K - BLACK,Ported Manifold,HSR 42mm Carb,Branch #5 Ported 883 Heads,Bob Woods W8S 0.590" Cams, SE -0.050" Perfect Fit Pushrods,SE 1200 Ignition Module ,Vance & Hines Straight Shot Exhaust,07 SE Air Cleaner,SE 40,000V Red Perf Coil,883 Jugs Precision Bored for Branch 30º Domed Pistons,& One Big Smile ;o), ~83TQ, ~83HP for now.
Old 7th May 2015
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
What lift on the cams? you running roller rockers?
Old 7th May 2015
Talking
I'm running bob woods prowler cams with 0.590" lift, with aggressive lobes. I am not running roller rockers though and my pushrods are -0.050" length to match the max flow of my heads at highest intake valve lift. No need for higher lift if doesn't flow more CFM.
Thanks.
Old 10th May 2015
From the look of the intake valve thru the intake port, looks like oil is seeping thru and the valve stem seals are worn. So I removed spring and took off seal and removed valve.
Have no new seals to compare to used ones to show any differences. So not sure how badly worn they are.
Any suggestions on using brake cleaner or carb cleaner to soak head with to help remove all the build up?
Old 14th July 2015
Turned out to be plain jayne running WAY to rich, which caused carbon build up, and pinging or detonation from increased compression ratio... Plus heads were NOT decked -0.050" in which the SE -0.050" pushrods were too short and after up to full operating temp... Started lashing. Smh
