0 New to me 55kh
Last Post: thefrenchowl
0 S&S Super E Carb
0 AGM battery for 76' XLH
Last Post: JonesL
Last Post: BigMek
Last Post: BigMek
Last Post: 1200CustomHD
0 so it's officially ended
Last Post: bklyngeezer
Last Post: LLOYD883
Last Post: hexnut
0 What cams are these
Last Post: keithnh
0 Iron head swingarm 6 Inch Stretch
Last Post: Uberstorm
Last Post: rocketnorton
0 Restoring stainless exhaust back to new?
Last Post: beard.tailor
0 My 08' Nightster
0 Nup 1009 (Bearing)
Last Post: retread08
Last Post: JacksBrother
Last Post: Clevspeed
Last Post: ReddTigger
Last Post: Cablejudge
  #121
Old 28th May 2012
gebeme's Avatar
gebeme gebeme is offline
Sportster/Buell Model: 883
gebeme is on a distinguished roadgebeme is on a distinguished roadgebeme is on a distinguished road
Looks like pics are gone but ASWRACING linked to these in#116:
http://www.hammerperf.com/ttxlcaminstall.shtml
http://www.hammerperf.com/ttspotcheckcamtiming.shtml
and I just found these:
http://www.nrhsperformance.com/tech_xlcaminstall.shtml
http://www.nightrider.com/biketech/x...200_page03.htm
Its a lot of info but I'm going to read until I understand then go for it!
1999 Sportster 883
-bored out to 1200
-Screaming Eagle intake & ehaust
Old 9th September 2012
sikk50's Avatar
sikk50 sikk50 is offline
Sportster/Buell Model: 883c
sikk50 is an unknown quantity at this point
I wish the pictures were still up. I really want to do this, but I'm a visual guy.
If anybody has the original pics and can post them or has another write up I would greatly appreciate it!
'06 883 Custom Black and Red with some junk
Old 10th September 2012
xena's Avatar
xena xena is offline
Assistant Administrator
sikk the person just before you posted some excellent links w pics.
Here's one: http://www.hammerperf.com/ttxlcaminstall.shtml#basic
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 12th March 2015
TheEssence's Avatar
TheEssence TheEssence is offline
TheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to all
Raising this thread from a three year grave. Just wanted to check and see if this cam process is the same for an EFI sporty as the pre-'07 carbed models.
"Ah! dear friend, you little know the possibilities which are in you."
Old 12th March 2015
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Year: 2015
Yep; the cams don't know how the fuel is metered.
Folkie
South East England Riders
Old 12th March 2015
TheEssence's Avatar
Hahahha. I just didn't know if Harley redesigned the motor at all when it went to EFI or if everything else was still the same motor just with a different fuel delivery. I'm relatively good at mechanical stuff, but to date I have never done anything with engine internals. Just the outer stuff, water pumps, intakes, fuel injectors...stuff like that. So, this will be my first go around doing anything actually inside the motor so I juuuuust wanted to be sure before I got going on this.
