0 Old oil in motorcycle question
0 Brembo Caliper Install...Lot of pics
Last Post: Redbeard2
0 Mukuni VM38 to Branch manifold boot
0 someone school me on suspension please?
Last Post: SLW210
0 19F+19R vs 18F+18R vs 19F+18R wheels
Last Post: Haegar
0 Got me a GPS Speedometer.
0 Early model Sportster rear fenders. XLCH
0 2000 up front wheel on a 1999 motorcycle
0 1958 xlch 883
Last Post: thefrenchowl
5 2000 XL Oil Plug Question to drain ALL OLD oil.
0 77-81 Sportster anyone have a 75002-77 temperature gauge?
Last Post: Michman
0 Iron 1966 XLRTT
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: wrkdWS6
0 What’s your take on Harleys ceo putting down the sportster line
Last Post: felis
0 1970 XLH Tach cable kinked
Last Post: Doc308
Last Post: AZbiker
Last Post: roccus
0 yost power tube guy
0 Fork Hight Questions
Last Post: AZbiker
0 New here - compression test produced meh results.
Last Post: randy3934
0 Ironhead Exhaust Poll
1 SuperStreet 2:1 Exhaust Systems for 2007-'20 HD® Sportster® Models
Last Post: warsawleague
Old 2nd March 2021
MadMaxUK MadMaxUK is offline
MadMaxUK is an unknown quantity at this point
Default Pre 04 pistons in later motor?
Just looking at the Wiseco K1661 flat tops but they're listed for 88-03 motors only. Any reason why they couldn't be used in a 2006 1200 motor? Are they longer skirts - clearance issues with the cooling jets?
Old 2nd March 2021
Exactly, on both accounts.
I.B.A.#26543,
Old 2nd March 2021
ReddTigger's Avatar
DITTO.
the 04 and up use a completely different bottom end.. so those parts aren't as interchangeable as the upper end stuff. some exceptions..
however, the piston squirters are 04+
States I've Ridden in
71.3 hp 70.8 tq
Old 3rd March 2021
Just off the phone to Wiseco. Their tech said that the skirt length is 1.979" on the 88-03 pistons and 1.967" on the 04 onwards. Might be a case of just popping them on the milling machine and taking off 0.020" ...
Old 3rd March 2021
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
Why don't you just buy the correct pistons? You haven't spent any money yet.
John
Old 6th March 2021
I can source Wiseco, SE or KB pistons easily but neither Wiseco nor SE do a flat top for 04 onwards and I refuse to use KB.
