Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 top end rebuild
0 New from Australia.
Last Post: Blue Custom
0 Remember these?
0 Brand new 2020 XL1200NS
Last Post: Veeflys
Last Post: mrmom9r
6 Happy Birthday Iree!!!
0 Tappet Block Cover Logo - Recognize?
5 Cruise-Mate (Europe)
0 Vintage tires
Last Post: Nitro57xl
0 ‘79-81’ rear wheel offset or spacing ing issue?
Last Post: the yukon sizzler
0 Plastic rocker box breather valves
0 Down on oil
Last Post: Billy1200
0 I need to polarize the generator each time I start the bike
Last Post: randy3934
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Sticky Ironhead trans
Last Post: Hap
0 Koso hd-01-04 2014+
Old 7th December 2015
fishman's Avatar
fishman fishman is offline
Sportster/Buell Model: M2
fishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the roughfishman is a jewel in the rough
Default 2009 XB12 engine in M2 frame.
Hi i'm putting a XB12 engine in my '97 M2 frame.
I don't want to use the injection, but use my Mikuni HSR42 carb.
Anybody knows how to run a stand alone ignition on the engines?
This is how she looked before:
ChefRex's Avatar
ChefRex ChefRex is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XB12X
Sportster/Buell Year #2: 06
Other Motorcycle Model: XLCH
Other Motorcycle Year: 65
ChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to beholdChefRex is a splendid one to behold
You're not going to run anything designed for a cone engine as you have nowhere to mount it, options are slim to nonexistening.
The front mount looks like it close to being where it need to be, swingarm pivot looks way off.
fishman's Avatar
Yes, enine mounts are not the problem. The ignition is.
I found this link: http://www.amm.haan.de/EFI_to_carb_X..._XL_models.htm
It uses the CPS for ignition. Shoud thid fit mu engine? In other words, are the XL and XB cranks the same?
ChefRex's Avatar
Sound like that would do the job, interesting.
You going to stick around for your build? I would love to follow along. Good luck!
fishman's Avatar
I just had a mail from Haan that their ignition works on this engine.
I will keep you all informed.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Why couldn't you use a TC88A?
Click Here to Contact Me
Does an XB12 use exactly the same voltage signals to the ECM as a sporty uses to the ignition? I am not trying to bust on you, trying to learn something as you know a lot more about electronics than I do, especially where computers are concerned.
fishman's Avatar
Good question. Never heard of it. Does it work with only CPK?
fishman's Avatar
Originally Posted by NRHS Sales View Post
Does an XB12 use exactly the same voltage signals to the ECM as a sporty uses to the ignititon?
I did some searching on internet. Looks like a good ignition for my setup. Only thing that worrie me is the MAP sensor.
Can i use the sensor that's connected to my M2's carb od do i need one from a xl1200?
If the voltages are the same the map sensor should be easy. Just get a carb manifold and map sensor for a 2004-2006 sportser.
