0 Remember these?
Last Post: heathkeenan
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
6 Happy Birthday Iree!!!
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 I need to polarize the generator each time I start the bike
Last Post: DR DICK
0 Vintage tires
Last Post: Nitro57xl
0 CV carb running way rich!
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
0 ‘79-81’ rear wheel offset or spacing ing issue?
Last Post: bobandy
0 Help identifying brakes
Last Post: bobandy
0 Ignition advice
Old 30th August 2017
thecarfarmer's Avatar
thecarfarmer thecarfarmer is offline
Sportster/Buell Model: pending
thecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud ofthecarfarmer has much to be proud of
Default I'm almost afraid to ask this...
...because I can see how this thread could devolve into a ��storm of "why would ya' wanna' do that - you'll go fast enough on pump gas" comments.
So, I'm going to ask for guys who've got first hand experience: on Evo Sportys, what kind of gains can be had on a hot bracket engine by going from 10.5 or 11.0 CR and pump gas to Max CR (basically, whatever dome you can stuff in the chamber) and real race gas?
Got to be some guys here who 'been there and done that'.
TIA,
William
Last edited by thecarfarmer; 30th August 2017 at 07:09.. Reason: fawkin phone auto-correcting stuff it oughta leave alone
AnaChris's Avatar
AnaChris AnaChris is offline
Sportster/Buell Model: 883xlc/1250
Other Motorcycle Model: FLHRCI
AnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant future
How about mid nines? Get Ya some head work and some oxygenated fuel.
Sent from my XT1254 using Tapatalk
2004 883C/1250, 30degree reverse dome 10.5:1, matching crushed XB1200 heads ported w/oversized valves, S&S roller rockers, Hammer .600 cams, billit intake, hsr42, TC88, innovative afr, bronze oil gear, alto carbonite clutch, patriot defender, all balls starter, 1 1/2 tank lift, f6 key relocation,steering damper
jcro61 jcro61 is offline
jcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud ofjcro61 has much to be proud of
On my 10.5:1 bike MS109 is a consistent 5-6 mph faster in the 1/4 than 93 Octane.
this isn't just a trend homie, it's a lifestyle...
Old 31st August 2017
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
IME, these things don't like compression, they love it. The more the better. Seems to help get the bike moving.
rocketmangb's Avatar
These things are also very hard to make compression (cylinder pressure) with.
When you get into big valves you also get big chambers.
At that point reverse dome pistons like those 10.5-1's just wont work any longer
I have 1.98 intakes in 80CC Chambers with .400 full dome pistons that are front and rear,meaning the exhaust valve pockets are much smaller and my numbers say the engine is 11.81-1 compression.
The Hot Street guys claiming 14-1 compression dont have pistons or heads anything like mine which is a grocery getter motor compared to they're engines.
Just dont Kid yourself what its gonna take to really haul ass.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Racepres's Avatar
Racepres Racepres is offline
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
Octane in and of itself simply inhibits Detonation [lights hard, burns a bit slower]
Does your engine need that?
Having been sponsored by 2 Different Fuel companies,and close enough to a 3rd...
I only use the Fuel I need.. On a Stock engine. or somewhat. the Unleaded [really unleaded, with No Alcohol] fuel is probably the very Best!!!
If you don't "pop lean" or encounter Detonation, out on the track...you can only go Slower by inhibiting "Burn".
Switching from 114 to 118 [on a whim] slowed us Down..
Fact
Old 1st September 2017
Racepres's Avatar
Oh
As Stated above...Compression is King..
11's to low 10's just with Compression and Timing!!!
Definitely required a fuel change.. The Proper Fuel
Old 2nd September 2017
That's a lot of performance!
BTW, I wonder what that difference would be throughout the year as the formulation of the pump gas was adjusted for the seasons...
rejeanprimeau's Avatar
Slower burning!!! Timing is the key with high compression engine with cams that can fill the chamber full. Combustion engine work with the expansion of the flame. You can built a high compression motor that run on regular gaz but It will be so hard to control timing and AFR, even on EFI, you'll choose racing gas; just easier to manage. The downside of racing gas is the price; That why HC bikes get trailered at the track.
Racepres's Avatar
I have Not found this.. Only maybe on inefficient combustion chambers, Think IronHead!
We Have both offroad gas, and Non-alcohol gas available where I am..
Makes a Big difference, especially as regards seasonal "formulation" changes.
I hate Alcohol.../it is the root of the Tuning and Performance Problems..
Unless you use 100% I guess!!!
