Last Post: Tipofthelake
0 Remember these?
Last Post: bill smith
0 Vintage tires
6 Happy Birthday Iree!!!
0 ‘79-81’ rear wheel offset or spacing ing issue?
0 Brand new 2020 XL1200NS
Last Post: Scruffer
0 CV carb running way rich!
Last Post: mikethebike61
0 1275 Map For Thundermax...Need Help
Last Post: XL1275
0 Down on oil
0 Sticky Ironhead trans
Last Post: Hap
0 I need to polarize the generator each time I start the bike
Last Post: DR DICK
0 Koso hd-01-04 2014+
0 Rear lights
Last Post: ironsquirrel
0 New to Harley - 2007 883R
0 Cancelling auto renew
Last Post: Billy1200
0 Clutch release mechanism
Last Post: Rioo
0 Help identifying brakes
Last Post: bobandy
Old 1st May 2019
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud ofNGOT8R has much to be proud of
Default Iron 883 drag race suspension setup
I have been researching drag race suspensions for my 2019 Iron 883 and would like to know what you guys/gals think about the following setup?
- Purchase a second front end and set it up with RaceTech specific rate drag springs, damping valves, Ricor Intimidators and Burly Brand preload adjusters.
- Add RaceTech single adjust drag shocks (specific to my weight) to the rear.
I will do most of my riding on the street, but for those times when I do hit the track it would be nice to switch over to a setup that will allow me to cut a good sixties without wheelies.
Note: I have never had a dedicated drag race setup before (only a custom rear drag shock on my old drag bike) and it handled decently on the street at 64". I was wondering if there is anyone in here that rides their drag bike on the street often and if so, what are the handling characteristics like? Are you able to get away with it by stiffening up the front and rear for the street, rather than having to swap out forks and shocks (if you didn't ride the bike aggressively into curves)? Thanks
Old 1st May 2019
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant future
If you strap the front down, you don't need a separate set of legs.
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Old 1st May 2019
Is there a specific strap kit available for the Sporty or will it require fabricating some brackets to run a strap kit?
Old 2nd May 2019
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Schnitz Racing has 20 dolla straps that will go onto the brake caliber mount and axle pinch bolt. EZ PEAZY!
Old 2nd May 2019
Thanks Madnss, I’ll check them out.
Old 2nd May 2019
madnss's Avatar
https://store.schnitzracing.com/schn...SABEgJFx_D_BwE
Old 2nd May 2019
madnss's Avatar
Lots of variables here, but I wouldn’t go tossing a bunch of money into a 2019 883 XL for strip use unless it’d be a dedicated drag bike. A good set of street shocks is fine for the strip. Like cyco said, strap the front end and go race. Or a great set of shocks and a front end rebuild with performance in mind.
If you are worried about wheelies then toss in a lockup clutch.
Imho, a street/strip bike is difficult to tune for the strip. Even though I still do it lol good luck!
Old 2nd May 2019
I can't help myself madnss. I am constantly trying to talk myself out of getting too crazy with this build, but at the same time, I am also a performance enthusiast, who is always looking to get a little more out of his toys. I actually enjoy the build process just as much as I do the riding. I will probably do the front end build and a really good set of shocks to round out the suspension. I have so many ideas for this project and I can't wait to get started on it.
Old 2nd May 2019
Intamators and racetech springs for your weight correctly preloaded is absolutely the best bang for the buck... Less than 400 bucks... This will let you out ride your tires and brakes really easily... A set of 300 dollar progressive rear shocks that are the correct length for your swing arm to be level with your lower frame rails with you on it and 1 click of preload. You will still want to strap the front down at the strip. This will be the best street strip compromise and still let you enjoy spirited twisty riding... But hey, I'm just a dumb redneck from Virginia...
Past experience with a similar setup would leave at 5500 and not lift more than 3 to 4 inches if you feed the clutch to it correctly...
Sent from my LG-LS993 using Tapatalk
Old 2nd May 2019
Thanks cyco! I haven't measured my rear shocks at full extension yet, but as the bike sits now, they're at 10 1/4" from eye to eye, so I would assume they are 11" shocks? You mentioned that the aforementioned setup would let me out ride my tires and brakes very easily. The bike does not have ABS. Should I be looking at upgrading brakes as well? I'm ok with 3-4" wheelies and will add the strap kit back to the list of things to get. I do have another question for you though. Does anyone run their bike with the forks lowered via the triple tree? That's what I did on my previous drag bike and that helped quite a bit to keep the front end down. Here's a video of a 1.51 sixty launch on that bike (white GSXR-1000 in right lane). I have been out of the game since 2012, and I know a lot has changed. However, I am looking forward to putting together a really nice package that will give me the best of both worlds.
https://youtu.be/ueAFOcm38Vg
