0 My 1250 to 1275 build
Last Post: Bryan1976
0 THE Hockey Thread
Last Post: Airbozo
0 Help ID’ing... Heads and jugs are weird?
Last Post: b0fh
0 Buying another IH
0 Locked up rear wheel
Last Post: mac93
0 Just wanted to thank everyone
Last Post: denguy
0 Intermittent Starter
0 78 sportster electric issues
0 The Oil Leak Rabbit Hole
Last Post: denguy
0 S&S Super E jets for 74 XLCH
2 Humble pie
Last Post: mac93
0 1977 Ironhead big fuel tank options
Last Post: Znabb
0 Need help with rear brakes for my wide tire project
Last Post: nicktopless
0 Calling all "Long Frame" riders...
Last Post: Magneto Sportster
0 vibration problem solved - CHECK YOUR FRONT ENGINE MOUNT BOLT!!
0 72 metal shavings in oil?
Last Post: Nilzar
0 Rear rocker cover?
Last Post: owlsplace
0 2004 rear mast cylinder
0 Does anyone know this XR750?
Last Post: John B
0 My '08 short chop
Last Post: Dudepants
0 First Startup after rebuild questions
0 XLH 883 1987. Please advise. (Jetting And Air Filter)
Last Post: xlh883-1987
0 25 April
0 Happy Birthday Decman!!!
Last Post: sltm1
Old 15th September 2018
jordan1200's Avatar
Default Front axles 99-2000 cast wheel
Are parts 43895-87B and 43895-00 the same? Interchangeable?
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
Graywolf Graywolf is offline
My parts book says 43895-00 is the front axle for the cast wheel and the front axle for the laced wheel too.
43895-87B is not in my book.
Sportsterpeia says it will fit 1998 and 1999s........ http://sportsterpedia.com/doku.php/t...01#front_axles
I think in 2000 is when Sportsters went to sealed front wheel bearings. Read through the Sportsterpedia section on front wheels.
Graywolf
43895-87B head length is app 2.715”,
43895-00 head length is app 2.546”,
2000 style axle has a longer shaft area but they both are same overall length.
This is in the 'additional information' under each part number in the chart.
Affects spacer lengths also.
43895-87B is in back, 43895-00 in front in this pic.
Old 16th September 2018
jordan1200's Avatar
Thanks, I am currently running an early 9's cast where and 2000 brake caliper on 2000 forks. Using a 99 axle.fits ok but had to shim brake calipers (dual disk with some washers to space them out to fit the old run and rotor setup.
Have a line on a cast 2000 black rim thinking it may be better to use the newer rim but I need to figure out exactly I will need to buy to complete the swap. If the parts are even still available.
Sent from my SM-T700 using Tapatalk
Scroll down on the wheel chart.
http://sportsterpedia.com/doku.php/t...heel_1986-2007
Find 2000 front wheels
Look to the letters lit up in blue
click on each letter to link to the pertinent bearing, hub and wheel spacer and axle part numbers for that wheel.
You can also search Dennis Kirk, J&P etc for an aftermarket set for 2000 wheels
