16th May 2022
Posts: 336 Sportster/Buell Model: XLH Sportster/Buell Year: 1982
Lubricating the clutch lever (and the cable if yours isn't lined) also helps a ton with getting the adjustment right.
The piniongear method, for reference: http://xlforum.net/forums/showpost.p...7&postcount=73
16th May 2022
Posts: 15,463 Sportster/Buell Model: xlch Sportster/Buell Year: 1960 Sportster/Buell Model #2: 883 C Sportster/Buell Year #2: '03
Originally Posted by Andy Hog
The plate you refer to, is that the clutch release pressure plate?
i've only heard the spring plate he mentions being an evo clutch issue.his ride.
16th May 2022
Posts: 6,971 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Oup my bad, taught it was an evo.
17th May 2022
Posts: 444 Sportster/Buell Model: Ironhead Sportster/Buell Year: 1981 Other Motorcycle Model: 1964 Triumph 3TA
My clutch lever is not the type that has those type of bushings, the cable itself is well oiled, I have a hydraulic oiler tool for this job.
Another mystery to solve.
17th May 2022
Rider Of The Iron Steed
Posts: 32,807 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
I guess then that it is not the original setup? The parts catalog 99451-85A shows that the bushings should be there right up to 1985
17th May 2022
we'd like to see what this non-conforming lever set-up looks like.
18th May 2022
This is what is on my 81, sorry I can't get the direct link to work.
eBay item number:304120330438
