0 Chinese sportster
Last Post: friday
0 Hello...it time I formally introduced myself.😈...
Last Post: Brad
0 KT - 2022 - Show A Little Backbone
0 Need help tuning VM38
0 1994 sportster shifter jamming
Last Post: roy_b
0 Adjustable Rear Brake Rod - Ride Like a Pro!
Last Post: Model H
0 2001 Cyclone: yea or nay?
Last Post: casual_obser
0 Cutting off Mufflers...Open Pipes
0 A Photo Catalog of Ironhead Parts
Last Post: Magneto Sportster
0 Mikuni hsr42
Last Post: onesicksporty
0 Swingarm pivot parts
Last Post: Kit352
0 Clutch Went Out of Adjustment
0 Header Bolts
0 Massachusetts 2022
0 Another Dealership Bites the Dust...
0 What did you learn about your Ironhead Today?
Last Post: Medyo Bastos
0 West Virginia fall run 2022
Last Post: kkbii
0 For a Finished Look - Bolt Cap Covers for OEM Bolts!
0 Installing a TRUE Stage I Air Cleaner System - DYNO PROVEN PERFORMANCE!
0 Front Turn Signals: Where do they plug into?
Last Post: FiftySixer
0 external adjustable float for dc12
Last Post: bill smith
0 Where do they go?
0 what size motor?
0 Do I need...
0 My latest build
tommy (76), richmac64 (58), nutter, KIUDOG (45), mikeLI_77, K Beggs (44), tekmoe (39), 1badhd (39)
Old 19th May 2022
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Thanks guys.
The threads were good. No slop.
Pins got a cleaning, light grease
I used blue locker on all the fasteners
The other side will be here Sat.
Steve
'01 Cyclone stock
'13 FXDC 96" stock
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
I have Russell drilled discs and EBC kevlar pads. They work great as long as you remember they aren’t sport bike brakes.
A 35mm fork is not a good foundation for stoppies....
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
Neither is an Speedmaster, or more than 80% of the tires mounted on the fronts of these noodle chassis’s
84rzv500r 84rzv500r is offline
Sportster/Buell Model: XLH 1200 S
Sportster/Buell Model #2: XR-1000
Sportster/Buell Year #2: 83
Other Motorcycle Model: RZV500R/R1 hybrid
Other Motorcycle Year: 1984
84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute84rzv500r has a reputation beyond repute
hmmm i dont seem to have a problem...
all off the shelf stock MoCo bits... save the bits to fit the blinkers and the 18" front to the rear..
1999 XL 1200 Sport RX, SE 7500 ignition, SE air filter, DynoJet, K&N, Cone Engineering 2:1 pipe, Storz Steering damper, with 2012 XR1200X perf forks, 3.5 x18" wheels front and rear, Galfer stainless lines, XR1200 4 piston front calipers, 18" dunlop trailmax mission 120/90 and 140/80 rear XR1200X perf shocks with 1" lift blocks...
20%er! Well done! Keep it up. I heard on the grapevine, 15% gets fun, 10% gets thrilling, 5 and under, unexplainable!!!
Broken images on this end.
I hope it's an Ironhead doing a stoppie!
