0 Idle / transfer ports Q
0 Photo bucket
0 Options for SE a/c cover
Last Post: lespaul6
0 WTB parts for a '96
Last Post: slamtry
Last Post: Roane
0 Vote for your favorite Babe Jump Babe.....
0 new air cleaner
Last Post: stikflote
0 Head work
Last Post: ericfreeman
0 Buying and installing starter solenoid for '74.
0 90" With an HSR45 Setup
Last Post: seajay
0 Will a late model head('07) fit a '92 Sportster?
Last Post: Boil1337
0 Glyptal?
Last Post: JonesL
0 Detachable Saddlebag Solution (pics, long thread)
Last Post: MrChris
0 External breathing systems
Last Post: Lone Rider
Last Post: 72 Ironhead XLH
0 To hone or not to hone... that is the question
Last Post: duffy
0 Broken bolt holes/ mounts, can they be fixed?
Last Post: TheSporster
Last Post: 1skullster1
Old 7th December 2019
budoka budoka is offline
Other Motorcycle Model: Knucklehead chopper
Other Motorcycle Year: 1940
budoka is an unknown quantity at this point
Default Update
Hello all, thought I’d post up about my progress.
After installing the 44 pilot jet and shimming the needle, the bike runs a lot better. Still a bit of backfire through the carb for the first few minutes after a cold start, but soon goes away. I’ll probably try a 45 or 46 pilot, and try rocketmangb’s plug suggestion and see if that helps, but it’s getting close. Runs wonderfully once warm.
Thanks for all the help guys!!!
-dan
Old 9th December 2019
Glad to hear you are getting better ignition operation now...
Originally Posted by budoka View Post
My 2002 Sporty has a pretty major backfire through the carb <SNIP>
Info.
Stock engine, heads, pipes. Air cleaner changed by P.O. Converted to points ignition. Stock cv carb, 42 pilot jet. Heads are not breathing into the carb.
I should have mentioned that it no longer has the VOES or any of the vacuum lines.
IXL2Relax, that is food for thought indeed. I have to admit that I’m much more comfortable with old school ignitions (I’m mainly from the school of VWs, Shovels, Knuckles, etc) but i know things have been changed over the years for a reason. Hmmm, gotta give the iggy a think or two I guess.
Just to give you some additional food to chew regarding an ignition upgrade:
Here's the Sportsterpedia section on the VOES that explains the concept and value of the upgraded ignition (such as the Ultima) that allows the VOES to choose between two ignition curves...
http://sportsterpedia.com/doku.php/t...lectric_switch
In later models, a MAP (Manifold Absolute Pressure) sensor replaced the VOES for even greater (more pinpoint) control of the ignition timing for various engine load conditions...
Here's the SP REF section on the Ultima Ignition:
http://sportsterpedia.com/doku.php/t...econe_ignition
If you do a seach on Ultima using the google search at the bottom of the page, you'll find lots of threads to read...
Old 10th December 2019
Default Thanks!
Thanks IXL2Relax,
That is definitely some info to chew on, and I’ll be sure to give it a slow think as soon as I have time. Right now I’m just busy trying to undo 17 years of neglect on this poor bike. I’m showing it some love, though.
Cheers!
-dan
Right now I’m just busy trying to undo 17 years of neglect on this poor bike. I’m showing it some love, though. - Cheers! -dan
Have at it - most bikes respond well to loving care...
Old 18th December 2019
cantolina's Avatar
cantolina cantolina is offline
Luvs me an artsy chick...
Sportster/Buell Model: 883>1200 XLH
Sportster/Buell Year: 97
cantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant futurecantolina has a brilliant future
You had me at "Converted to points ignition" I. Can't. Even.
Took me half the thread to catch that.
Good Luck!
My suggestion: go back to stock ignition, and try the mods suggested within. Newer technology is rarely worse. Even with the stock ignition, I often had to make mixture changes in Western New York, throughout the year.
Wow. Converted to points.
First, thanks for taking the time to look at my post. I know you guys have a 1000 and 1 things to be doing and just for looking, THANKS!
my 2002 Sporty has a pretty major backfire through the carb that I’m trying to get sorted. If anyone has some pointers to help me, please do share. I’m no noobie to wrenching, been working on bikes and cars since I was old enough to hand wrenches to my old man, but it’s always good to talk to folks who’ve been there before you.
Info.
At this point I’ve checked the timing, replaced the points/condenser, rebuilt the carb, adjusted the idle mixture up to 4 turns out (still no black smoke out the exhaust). I’ve replaced the intake seals both on the heads and between the carb and intake, and WD-40 sprayed around the intake does not change the idle speed. The diaphragm on the slide is old and stretched and needs a bit of gentle coercing to get back under the cv cap, but responds well when air is fed into the port on the front of the carb. Regardless, I’ve ordered a new diaphragm and slide along with a 44 pilot jet which should be here tomorrow.
The backfire goes away when I open the enrichener a bit, and it gets better as the engine warms up.
Anything I’m missing here?
Many thanks,
-dan
~Chuck
"entia non sunt multiplicanda praeter necessitatem"
Occam's Razor...
in English: "entities must not be multiplied beyond necessity."
My definition: "The simplest answers are the most likely"
~NRHS machined 1200 conversion, shittin and gettin...
XLF Tuning Stickies
Charging system troubleshooting
rocketmangb's Avatar
Where ya been Chuck ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Originally Posted by cantolina View Post
~Chuck
Man - Did you just wake up from a Rip Van Winkle ???
You have so many good threads I enjoyed...
