Keep & Kill
Last Post: fafcpa
1st March 2012
Posts: 61 Sportster/Buell Model: Sportster Sportster/Buell Year: 1987
Possible generator/regulator problems?
Hey guys.
I put a brand new generator and regulator combo on my '81 last summer. Shortly after (about 3-5 days) I noticed the generator light wasn't going completely out at a higher rpm. (it would stay on at a low rpm like normal but would only dim at a higher rpm) I tested the output with a meter and I'm getting 12 volts at roughly 2,000 rpm. I vaguely remember someone telling me on here that it should test out at 13 volts. Like I said brand new gen/reg. So it it charging with only 12 volts at 2,000 rpm?
Thanks any help is appreciated.
1st March 2012
Posts: 461 Sportster/Buell Model: xlh ironhead Sportster/Buell Year: 1977
Went through this last year. DON'T underestimate the regulator ground. Replace the wire and clean the connections. Cost me 200+ at my local indie for a 6 inch ground wire. Second, get a ammeter from autozone and do the test in the stickies to see how much charge you are throwing. Good luck.
1st March 2012
Posts: 2,359 Sportster/Buell Model: xlh convert to xlch Sportster/Buell Year: 1978 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1972 Other Motorcycle Model: Sportster 48 Other Motorcycle Year: 2010
did you polarize the generator after you installed your new parts?
If your gonna do something, do it right!
1st March 2012
Posts: 9,370 Sportster/Buell Model: XLCH 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 75 motor in Norton frame. Other Motorcycle Model: 42WLA 45, Harton, Narley Other Motorcycle Year: 1942
Was is a CycleElectric gen and reg? Or Chinese aftermarket parts? If it is the latter, it could be faulty new parts. Been some problems with them reported on this board from time to time.
But first, like said above, check ground connections, all wiring, polarize generator etc.
1st March 2012
I did polarize. And as far as the make of generator I think it was probably a v-twin gen/reg. the problem with the light not going all the way out at a high rpm started just days after putting the new gen/reg on. So I'm not sure. I do know that it was expensive to have it on for only days before it started doing this. The regulator alone was $100 and the generator was well over that...if I wasn't so nauseated over spending that kind of scratch to have it just break anyway I'd just buy an alternator conversion kit. But I can't bring myself to believe that either the gen or the reg are bad...but they probably are.
1st March 2012
I just looked at my receipts for the generator and regulator and they're made by "V-Factor" I'm not sure if this will help.
Thanks
1st March 2012
Posts: 2,718 Sportster/Buell Model: FLCH Sportster/Buell Year: 61 Sportster/Buell Model #2: XLCH Kit Bike Sportster/Buell Year #2: 60
follow this sticky to figure out the problem:
http://xlforum.net/forums/s...ad.php?t=39146
then we can figure out how to fix
Scott
'61 'CH
'60 'CH
1st March 2012
Posts: 1,409 Sportster/Buell Model: xlch 73 Sportster/Buell Year: sold Sportster/Buell Model #2: 1997 1200s
hi there is the reg on the end of the gen or is it a frame mount reg if it is a frame mount reg try running a wire from the ground on the reg to a ground wire in the harness as this will ensure a good ground
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
1st March 2012
Hi. It's a regulator on the end of the generator.
Reason: Misread an earlier post.
1st March 2012
V-Twin = widely variable quality of parts. Some good, some godawful.
But no need to panic just yet.
Check your connections and ground wires etc. Check main ground wire from the battery too, and battery connections etc.
And check that you have the regulator wires wired up according to the instructions with the gen/reg. It may be a little different from the stock set up.
Then run the checks in the link ScottFisher posted above.
