Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Sportster Motorcycle Custom Finishing
0 Value of a Boattail?
Last Post: valvebeater
0 Future of the sporty?
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 Paulie420 needs your help.
Last Post: Paulie420
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Not charging issue!
0 so,, amazing,,how u guys are sucking,, knowlege
0 HAMMERPerf 90" In the Works
0 Range With EFI 4.5 Gal Tank
Last Post: jzink0883
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
0 Joe Minton article on HSR 42 tuning
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
SoCal 1200N (57), riverar7 (53), rx3732 (44), gnrxl2002 (40)
Old 16th October 2015
64physhy's Avatar
64physhy 64physhy is offline
64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold64physhy is a splendid one to behold
I would powdercoat it myself, but don't have an oven big enough for the frame.
'00 1200 with some stuff done to it.
"The strength of the wolf is the pack, the strength of the pack is the wolf."
it can be cured in sections with heat lamps, just need to tent it. I actually cured a guitar neck with a heat gun because I could not get it into my oven. you have to watch for flow out and then expand the melt slowly and keep the heat moving to prevent bubbles. def not for faint of heart. many body shops probably would let you use the oven. however, most do not get that high of a temp. google and you will find shall I say enterprising individuals that do the impossible cures with redneck ingenuity.
