0 900 heads contd..
Last Post: spacecoast
Last Post: wharg
0 Bars on C Riser?
0 Clutch Spring plate poll
Last Post: jammantoo
0 crack in head
Last Post: slamtry
Last Post: 883openpipes
0 the far west burbs of Chicago
Last Post: lugster
Last Post: BrokenIron
0 More of a reintroduction
Last Post: lugster
0 05 and 73
Last Post: TT60
0 Racing tem up with Hero moto corp
Last Post: retired
0 The White Bike is the Right Bike Thread.
0 Starter motor
Last Post: sleighcrane
0 Found my bike on Google maps
Last Post: gravydog
5 Am I looking for Trouble ?
Last Post: Crosshairs
0 WTF Happened
Old 26th April 2012
scottsxl1200's Avatar
scottsxl1200 scottsxl1200 is offline
Other Motorcycle Model: Fatboy
scottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant futurescottsxl1200 has a brilliant future
Default Dyed Heavy Breather
So after painting my bike green I tried to find a replacement filter to match the bike, with no luck. So I removed the red color using Rit's fabric color remover then dyed it mixing there yellow dye with a little bit of their royal blue. What do you all think?
I didnt say it was your fault, I said I was going to blame you!
Old 26th April 2012
Big-Ed's Avatar
Big-Ed Big-Ed is offline
Sportster/Buell Model: Sportster Sport XL1200S
Sportster/Buell Model #2: Fatboy 1450 FLSTFI
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Kawasaki KDX125sr
Other Motorcycle Year: 1991
Big-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to all
Looks great & matches the bike pretty well!!..
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
Old 26th April 2012
gchristopher9 gchristopher9 is offline
Sportster/Buell Model: 1200c
gchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nicegchristopher9 is just really nice
Not sure if you are aware of this or not, but that red color is not really a "dye" so to speak. It is oil that helps to filter out super fine particles. Removing it will definitely decrease the effectiveness of the filter.
Old 26th April 2012
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Definitely different.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 26th April 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Other Motorcycle Model: FXDL
AustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud ofAustinXL has much to be proud of
I think it looks pretty slick, never thought of that before. Rep for you, good job!
Old 26th April 2012
Big-Ed's Avatar
+1 on this, It is a k&n element that the Harley heavy breather has & the filter element uses the oil to catch the dust & dirt..
Old 26th April 2012
Screw Loose Dan's Avatar
Screw Loose Dan Screw Loose Dan is online now
I think I like Sportsters
Sportster/Buell Year #2: 2016
I do like how it looks. Pretty good idea. You'll just need to use a non-red oil on it.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 26th April 2012
Thanks everyone. And yes I'm aware the red is oil, what I have done is sprayed the oil on the inside of the filter but as mentioned, I think I am going to have to find a clear oil to use.
Old 26th April 2012
caain's Avatar
caain caain is offline
Sportster/Buell Model: XL883L
Other Motorcycle Model: FXDB
Other Motorcycle Year: 2007
caain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nicecaain is just really nice
Looks great! And definitely a novel idea as far as I know. Since you've got the oil thing covered you should be good to go.
Old 26th April 2012
Yeah, the problem is that the oil wants to soak into the filter so I dont have it covered as well as it should be but I'm confident I can find a clear oil that will work.
