0 The country store
Last Post: lugster
Last Post: rjg883c
0 headight housing
Last Post: VaFish
0 Diagnostic help
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
0 Shop Trick of the Day: Proper Welding Techniques
Last Post: BILLETPROOF
0 first harley- help!!
Last Post: Joesdaddy
Last Post: Blowupster
0 oil cooler or not?
0 Intro from New England
Last Post: oreocat1
Old 25th March 2008
ct_miller13's Avatar
ct_miller13 ct_miller13 is offline
Sportster/Buell Year: 1985
Other Motorcycle Model: CB cafe, a few enduros
Other Motorcycle Year: >71
ct_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nicect_miller13 is just really nice
I used 220 grit to scuff them up. I went with the Krylon heat paint, good to 1500 they say. I used the Rustoleum on a different bike, it didn't seem to hold up as well as the Krylon. Also, the Krylon has a slightly glossier finish than the Rustoleum.
Old 25th March 2008
Johnny Wolf's Avatar
Sportster/Buell Year: '95
Other Motorcycle Year: '03
IMHO don't use regular high heat "BBQ" paint. It drys flat like a chalkboard and is hard to maintain. I did mine last June 07 with Dupli-Color 1200 f Ceramic black (drys to a satin finish).
I scuffed the chrome pipes with 220, and primered with three coats. One flash and two heavier, then three coats of black, again one flash and two heavier.
I had the chrome heat shields media blasted and painted them the same as described above.
Fast forward 9 months:
The pipes are a little gray close to the heads, but hardly seen because of the heat shields. The shields look the same as they did the day I sprayed them.
On a side note, I couldn't cure the parts in the oven as recommended, so the first time I rode I buggered up one of the heat shields with my heal. I scuffed it a bit and fogged in a touch up. It looks great.
Next time I'll start and cool the bike a few times to cure the paint better.
Old 25th March 2008
ShadenGheist's Avatar
ShadenGheist ShadenGheist is offline
ShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the roughShadenGheist is a jewel in the rough
Originally Posted by soro View Post
Would sandblasting the chrome parts give a better surface for the paint to adhere?
Aluminum Oxide works great for removing Chrome, but you'll need a Media Blast cabinet. Unless you want to waste 30 bucks for the media. You really won't need to get all the chrome off, just dull the surface uniformly and then clean it well with soap and water.
Ask not for whom the Bone Bones...
It Bones for Thee.
~~~~ 'Bender' Bending Rodriques ~~~~
Old 25th March 2008
Sporting Lad's Avatar
Sporting Lad Sporting Lad is offline
Sporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud ofSporting Lad has much to be proud of
Cool It's not mufflers, but it's close!
I used a product called "VHT Flame Proof coating" by PJH Brands of Scottsdale, AZ. Made in USA. It's a rattlecan. Says it's good to 1500 deg F.
I used it on my heatshields last spring. First I took the chrome bits, "roughed them up" with whatever sandpaper I had laying around (I don't know what grit), then wiped them down good w/ acetone. When they were ready I took them out into the bright sunshine and hit them with three (3) coats of the above.
As soon as the paint was dry enough I reinstalled them and went for a ride.
That cured them of any thoughts they may've had of returning to their old chrome ways.
About two months later I spun out in some gravel and sort of, well, ended up doing a 180 and high-siding onto the bike's right side. All's that happened was that the heat shields got a few scrapes and scratches. I waited until autumn (to see if anything else might occur. Just kidding) then gave them another coat or two of the stuff. Now, it may not be the most bulletproof method--like, it ain't ceramic or powdercoat--but nothing will stand up to the abuse that occurs to the underside of an exhaust, so I figure if they get scratched, so what? Just spray 'em again in the off season.
Actually, this paint has stood up remarkably well and adheres fine to the chrome. And it's cheap.
What more can you ask?
[SIGPIC][/SIGPIC]'06 XL 883/1200, [B][I]"BLACK MARIAH":[/I][/B]
Wiseco K1655s; Joker Machine AC; SE 'SP' muffs w/ Cycle Shack baffles; OEM SHOCKS on Tamarack -1" blocks; Metz 880s (110x19; 160x15) on laced wheels; Progressive fork springs; 4.5 gal tank; ReddTigger Mod Gauge Mount System...
See thread [url]http://xlforum.net/forums/showthread.php?t=1102057[/url] for a "[I]pictorial history[/I]".
Old 25th March 2008
Scooter_Trash's Avatar
Scooter_Trash Scooter_Trash is offline
Sportster/Buell Model: Rat Bastard
Other Motorcycle Model: Honda CL175-Rot'n Bastard
Other Motorcycle Year: 1970
Scooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really nice
I just finished scuffing up the pipes tonight and like always I sit back and marvel at the brushed aluminum look. I think I'm going to keep them brushed for awhile. I can always paint them later. It's a hell of a lot easier to do it this way than it is to paint and go back to brushed.
Now if I can just figure out a way to install that mooneyes air cleaner that's been sitting on my workbench.
Old 25th March 2008
When I scuffed my fender struts prior to paint I was thinkin' the same thing. They looked really cool.
Which ones did you cut up? The set in your sig pic, or...???
Old 25th March 2008
the tommy guns in the sig pic. I'll post a pic wednesday. still trying to decide if i like the look.
Old 26th March 2008
rottenralph's Avatar
I wanted to add a comment about my weekend Duplicolor experience. The gloss paint seems to be really sensitive to the temperatire and I found that a couple of coats of semigloss which seams to go on really smooth and even and then following by gloss leaves a perfect finnish. If you just put the gloss over the primer, the paint pools and has to be wet sanded between coats till it finally covered properly. I have never had more problem with a can of paint then I had with the gloss. The gloss simply sucks till you can have a good base of black to work with.
Old 26th March 2008
06sportie 06sportie is offline
Sportster/Buell Model: 883
06sportie is on a distinguished road06sportie is on a distinguished road
man i reallyy want to try this but i jus cant bear the thought of paintin something u dont have to paint brick paneling aluminum excetra
Old 26th March 2008
Huh...?
Spell-check can be your friend
