0 The country store
Last Post: lugster
Last Post: rjg883c
0 headight housing
Last Post: VaFish
0 Diagnostic help
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
0 Shop Trick of the Day: Proper Welding Techniques
Last Post: BILLETPROOF
0 first harley- help!!
Last Post: Joesdaddy
Last Post: Blowupster
0 oil cooler or not?
0 Intro from New England
Last Post: oreocat1
custom, customizing, spray paint
Old 30th March 2015
LondonMan LondonMan is offline
Sportster/Buell Model: Forty Eight
Sportster/Buell Year: 2015
LondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of lightLondonMan is a glorious beacon of light
Default Spray painting advice required
Hi Guys,
At some point I will probably want to change the colour of my bike. Although its not something that I will do immediately, it reminded me that this forum might be a good place to ask this question.
I need some answers because it serves another purpose for me. Although I would like to learn to customise my own bike. I have another area of interest, which is related to my work (nothing to do with bikes) and I have been for some time trying to figure out how to spray paint on clean metal sheets, so that it sticks and that it doesn't scratch off easily. I even bought a compressed air machine a couple of months ago but never got the chance to use it. I was told that I could use some of the techniques used by car manufacturers where they add a plastic coating to stop it getting scratched. I am trying to figure out of these tools are available to hobbyists? I am willing to spend money, but not enough buy an assembly line machinery
I want to know is it possible to spray paint your bike yourself, or must you go to a specialist garage that does this sort of body work spray painting?
Have you spray painted your bike, and how did it go?
Thanks.
Old 30th March 2015
S/RConcepts's Avatar
S/RConcepts S/RConcepts is offline
Sportster/Buell Model: XL883-1250 "Bad Medicine"
Sportster/Buell Year: 1989
S/RConcepts is an unknown quantity at this point
LondonMan,
It's absolutely possible to spray paint your tins yourself, I have done so on several occasions. The two biggest things to doing it successfully are:
1. Use a good-quality paint. I like using Duplicolor Perfect Match, since it's readily available in most auto stores over here (I'm not sure if it's available in the UK), applies easy, and the colors themselves are very accurate.
2. As with all body work, proper prep is 90% of a good result. Use a good sandable primer, sand it down and make sure it's as smooth as possible before thinking about laying a basecoat. After the basecoat, use a clearcoat of the same brand, let it dry, then make sure to wet-sand and polish the paint to remove the texture (orange peel). I find that most people skip the wetsanding and polishing when using spray paint, and that's part of the reason why it looks so bad.
If you take those two major things into account, you should be fine. Everyone that looks at something on my bike that I've had to spray paint can't believe that I had done so, it turns out that good. Then again, I used to work in a professional auto body shop, so I know a few tricks to use
Old 30th March 2015
Green hornet's Avatar
Green hornet Green hornet is offline
Sportster/Buell Model: Sportster 72
Other Motorcycle Model: Honda CBR 1000RR DragBike
Green hornet has disabled reputation
On the clean bare metal sheets........ Scuff them with a red scotch brite pad. spray some acid etch primer and then paint. If they are greasy you have to de-grease them first. The acid etch primer will help the paint stick.
Old 30th March 2015
Lone Rider's Avatar
Sportster/Buell Model: 1200
three words..........2 k clear, it is a 2 part clear see link http://www.spraymax.com/index.php?id=361&L=1, especially the tank as it is gas proof, doesn't yellow over time, but you must use with caution (respirator)high toxic stuff, here is a fender i did, three coats of clear, stuff goes on flawless.
