0 Value of a Boattail?
Last Post: valvebeater
Last Post: spitfirechopper
0 THE Trainspotting Thread
0 Paulie420 needs your help.
Last Post: Paulie420
0 1977 Bright Blue
Last Post: Airarbiter
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
Old 2nd January 2016
slcharger's Avatar
slcharger slcharger is offline
Sportster/Buell Year: 2014
Other Motorcycle Model: Triumph Thunderbird 1700
Other Motorcycle Year: 2010
slcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud ofslcharger has much to be proud of
Your guess is way off base..
performance engines are about combinations.. and the proper combinations to create the end result..
the additional 48cc or 4% increase is drastic when the end results are looked at.. which you will not get without the 4% increase in displacement.
now if you just add the 1250 kit to the same cams, etc, then you're not going to see the drastic results,, but if you properly apply the criteria to maximize performance then the 1200 can by no means achieve what is available to the 1250..
it's been shown to have engines over 120hp with 1250cc..
it's been difficult to get a 1200 over 100hp..
So, please enlighten us. What is the exact difference. Why is the 1250 kit so good ?
ReddTigger's Avatar
The "EXACT" difference is a 4% increase in displacement.. but whats done with that displacement is what the difference is.. and there is no exact because certain parts work better one way vs another.. but more so adds a couple more % to the equation due to the larger bore opening up the area around the valves and giving better breathing..
spend a little time on some of the conversion threads and you'll soon learn why the 1250 is the way to go if you want to create a high end high performance sporty without splitting cases..
we have two great vendors of the 1250 kits and their respective pages have lots of info..
in alphabetical order..
http://www.hammerperf.com
www.nrhsperformance.com
States I've Ridden in
71.3 hp 70.8 tq
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Thanks Red you are spot on
rejeanprimeau's Avatar
You can get the Branch Okeffe kit at the dealers but, the 3500$ Hammer and NRHS charge just get doubled and add another 3000$ to have the dealer install those kit; not sold over the counter. The stage 4 Screamin Eagle B-O will get you at 115 hp with the 575cams for a 10000$ bill.
I rather hammer it for 3500$ myself and go for 120 HP on 883 heads.
And the most cool part sportster ever had was those clutch cover that say sportster back in the sixty, nothing cooler than those.
slcharger's Avatar
Now, this sounds interesting. What is that about, I mean the 883 heads breathing better ?
slcharger's Avatar
You have a picture of those ?
jackddg22 jackddg22 is offline
Sportster/Buell Model: Hammer 1250
Other Motorcycle Model: 2015 Low Rider
jackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nicejackddg22 is just really nice
Think that 883 heads can be made to breath AS WELL AS 1200 heads with a lot of work. Not better
Hammerperf.com or click the vendor add.
Old 3rd January 2016
steelworker's Avatar
Other Motorcycle Year: 2016
Okay, let me start the show.
In my opinion the open belt drive is the part / accessory that add the most coolness to the bike.
I think you're at least 10 years too late. The craze for billet bling has been and gone.
