0 Clutch blow up
Last Post: seajay
Last Post: mrmom9r
0 Rear Fork Maintenance, How to
Last Post: Mission1
0 top end rebuild
0 Do not buy this oil!
0 One for the dad joke collection
Last Post: maltesefalcon
0 New Harley CEO
0 random rattle
0 Membership $20? am I missing something here?
Last Post: hexnut
6 Hello Folks
Last Post: bklyngeezer
0 Mileage
0 Bike wobble question
Last Post: Doc308
0 New Product Sneak Peek!
Last Post: XL1275
0 1960 XLCH in the UK
0 Cam chest vent fitting
Last Post: BigMek
5 Is factory Stage 1 worthy?
0 G'day from London, England
0 73 Electric Start won’t run after firing
0 Oil leaking
0 Regulator/rectifier question
Last Post: LenC
0 883 having trouble shifting
0 Wheel swap
0 Stock vs. Modified
Mike1nw Mike1nw is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Suzook Burgman 400/ 2008
Mike1nw is an unknown quantity at this point
Default Disassemble tranny HELP
2007 883
https://partsfinder.onlinemicrofiche...ISSION%20GEARS
So I'm down to left side engine case setting on my workbench, with 2 tranny shafts attached.
I just cannot find how to go further. Books and YouTube vids show the old style transmission. Where you pull a plate from the primary case with tranny guts attached.
Can someone provide a link to getting the main shaft out? Looks like a nut holds the countershaft in (left or right thread?) It's no. 1 in the pic attached above.
Maybe then the main shaft will pull out?
OR do I have to take to the shop at this point
deguireb deguireb is offline
deguireb has disabled reputation
hey, I would assume that you have the factory service manual - correct?
What happen to you transmission?
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
You need a shop press to do this the right way.
The shafts are pressed into the bearings which in turn are pressed into the cases.
Buy new bearings also, you will damage the old ones in the process of removing them.
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
Looked this up for the 2006 bikes, fsm shows pressing both out at the same time with a 'transmission remover' tool. there is also a special tool/ jig ( in the fsm) used the press the transmission shafts into the bearings in the lh case.
Post no Avatars!
There is a way around the special tool.
You remove all the gears/bearing from each of the shafts while they are still in the cases.
Then you can press each one out separately.
Either way you need a shop press and the HD service manual.
Yes, I just found FSM on line, which I'll read.
Reason for this disaster: broke off mainshaft nut & part of shaft. Impact gun
and I have access to a press, local German car mechanic, he can fix anything
Old 4 Days Ago
"You remove all the gears/bearing from each of the shafts while they are still in the cases.
Then you can press each one out separately."
No can do. Some of the gears are integral to the shafts.
"Buy new bearings also, you will damage the old ones in the process of removing them."
I thought so. You are pressing shafts out of bearings, without being able to support the inner races. You'd think the bearings would be trashed. BUT the FSM does not state, buy new bearings....
"Either way you need a shop press and the HD service manual."
I was trying to find an old-timer to press these. Guess I'll end up buying a 12T press... I tried the local MoCo dealer Apparently, they aren't allowed to actually HELP people.
