0 Massachusetts 2022
0 1977 Sportser - Finally running, but couple issues
Last Post: ironbar
0 Before and After pictures/Videos of your bike (All Welcome)
Last Post: Ghostdog
Last Post: slowcycle
0 33.4mm fork bushings
Last Post: Staffords
0 My XLCH/XLR Hybrid build
Last Post: davixlrtt
0 A Reliable Engine
Last Post: Ghostdog
0 72 ih stroker advise needed
3 Rear galiper bracket spec.
Last Post: DG Racing
0 On board voltmeter
Last Post: Len PA
0 Secondary Pulley Sprocket Quality
0 Oil Soaked Air Filters
0 Ugly Duckling
Last Post: DR DICK
0 extortion
0 incredible complainers
0 Regulator test 1974 xl
0 rotor
Last Post: DR DICK
0 Aftermarket Ironhead Seats - ID?
Last Post: DR DICK
0 New to me '74 xlch
5 Frankenstein forks- preload?
Last Post: WVDevil
IronHead83, AMATRAVELER (60), ZYBAN (58), tom_ski (57), mid30 (56), im_justin_sane (54), DOZER (52), acman145acp (52), espacef1fan (37), fernandopn (37)
  #31
Old 26th November 2014
Kauz789's Avatar
Kauz789 Kauz789 is offline
Sportster/Buell Model: Ironhead sportster
Kauz789 is an unknown quantity at this point
Sup every one...i been a long time reader and fan of alot of u guys here on the forum this forum is like a bible to me..i love my ironhead to the point i lose sleep thinking of keeping her running right and restored..and reading this thread i did a compression test on ol'glenda and found shes reading 120-120 is that right?..btw 1980 ironhead sportster electric start
ratt2y ratt2y is offline
Sportster/Buell Year: 1976
ratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the roughratt2y is a jewel in the rough
I am not sure about this but I don,t think you can fill a combustion chamber to 14.7 psi with an intake valve 1/3 the size of the cylinder.you know what I mean LIFT/DRAG air flow.
Jafa39's Avatar
Jafa39 Jafa39 is offline
Sportster/Buell Model: XLH1100
Sportster/Buell Year: 1986
Jafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enough
120/120 is fine, its not the actual figure but the difference between them that is important.
Shake, rattle and roll...is there any other way to travel??
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
Originally Posted by Kauz789 View Post
... i did a compression test on ol'glenda and found shes reading 120-120 is that right?...
Just checking, did you remember to keep the throttle wide open during the test? and to have the engine at full operating temperature? If either of these was missed your result is less than it would be.
Welcome! to the IronHead forum.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Kauz789's Avatar
Yes i drove around town got fuel and back to my garage about 1/2 hour to 45mins and yes did the test with the throttle open
Old 27th November 2014
xlhiron's Avatar
xlhiron xlhiron is offline
xlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enoughxlhiron will become famous soon enough
I don't think the guy has done a compression test yet. He says he read it should be 110 psi. How about it Brownskull, done it yet? Borrow/buy a gauge. Warm it up, take both plugs out. Screw the gauge in one side then the other with the throttle open
and report. Lets put this to bed.
Catching a yellow-jacket in your shirt at seventy mph can double your vocabulary.
Old 3rd January 2015
thinks ted.Fe Head just how fast can you kick an iron head?do a test of a running motor,you might get 250psi? I do see the math.I mean one lung it at 2000rpm.checking other jug with no fire?
Old 3rd August 2021
Sloperboy Sloperboy is offline
Sportster/Buell Year: 75
Other Motorcycle Model: BSA
Other Motorcycle Year: 28
Sloperboy is an unknown quantity at this point
Hallo what is the complet Timing Ratio of the R5 in Degrees?
The one of my BSA is
IN op 45° BTDC Clo 65°ABDC
EX op 65° ABDC Clo 30°ATDC
Comp Rate is 8:1 130psi is what i get with the Lowcomp Sporty Piston
The main problem is a overheatet EX valve.
Some Old man told me i have to set the timing so to get a flush of fresh air over the Ex valve to cool it....
Best Regards
Old 3rd August 2021
Sportster/Buell Year #2: '03
did someone put low compression pistons in it?they were 9:1 from the factory.you'll get the best comp readings with the motor hot,throttle held wide open.
Old 3rd August 2021
Ferrous Head's Avatar
Sportster/Buell Year #2: 1966
120-120 is what I would expect on a well used engine.
try the test again after squirting a little oil (enough to coat the walls/rings) into the cylinders.
If the pressures some up 10 PSi or so, your just looking at normal wear on an Ironhead of that age.
With a fresh battery an electric leg should be fast enough to get you a correct reading. Kicking is always "Problematical".
