0 48 O2 sensor?
0 Howdy ya'll
0 Hello from Tampa, Fl
0 Another from the Phoenix area
0 Phoenix AZ
0 Hello from Philadelphia, Pa
Last Post: ronccc
0 Starting issues (No Spark)
Last Post: ronccc
Last Post: marcusorelius
0 [Ignition] Points in a 2000n evo
Last Post: lostjohnny
0 back to factory clutch
0 Battery melt down
Last Post: stick shift
0 removing clear coat on fork lowers
0 Resto-Repair 84 ironhead
Last Post: Robyart
0 Getting Hammered
Last Post: Bryan83taco
0 1968 Vin number help
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 1960 XLCH in the UK
Last Post: lynnx
Last Post: robbie202
0 Voltage Regulator
Last Post: 72 Ironhead XLH
0 88ci Sport Rod
Last Post: rubine
1200, electrical, sportster, starter, xlh
Old 9th March 2016
Mojave3555 Mojave3555 is offline
Mojave3555 is an unknown quantity at this point
Default 2003 XLH 1200 stater keeps cranking
i recently aqquired an XLH with ape hangers and when i turn the key everything is normal but when i put the kill switch to the "run" position the bike cranks like im pressing the start button but will not start because there is no spark can anyone help?
Old 9th March 2016
Graywolf Graywolf is offline
Look for pinched wires in the right handlebar button cover.
Graywolf
Old 10th March 2016
if I remember right, power to on/off, power jumped to start button, only operates when in run position, could be starter button or cross wired
Old 10th March 2016
sportsterdoc's Avatar
You passed the memory test...you may now pass Go and collect $200!
Yes, stop/run powers start switch.
In this case the w/bk from the stop/run may be pinched to the bk/r to the starter...or the start button contacts may be fused together.
