0 In Tank Oil Filter?
Last Post: maverick31210
Last Post: 83ironman
0 How many helmets?
5 Jiffy Standing
0 Winter reading........
14 DEAR Harley Davidson,
5 Oil pump pressure
0 Is this 1200R worth $4500?
Last Post: longride
0 Bushing alignment
0 Who's still riding???
Last Post: 1977iron
Last Post: kmul
0 THE Trainspotting Thread
0 Big Bore '03 883R :)
Old 2nd December 2012
Folkie Folkie is online now
Default Chain Inspection Cover And Gasket Changed In '09
The rubber primary chain inspection cover gasket # 34986-04 was replaced in '09 by a metal and paper gasket # 34990-08.
At the same time the chain inspection cover itself was changed:
Chrome # 34761-04 by # 34761-04A.
Polished # 34993-04 by # 34993-04A.
Black # 34794-05 by # 34794-05A.
Apparently, the only difference with the new covers is that they are thicker, to go with the new thinner gaskets. The new covers come with the gasket.
There are several threads about this; here are a few of them:
My '06 has obsolete parts. WTF???
First issue with the Nightster that wasn't my fault...
Primary inspection cover gasket
Torque for primary chain inspection cover screws
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Don't know about the old ones, but the new ones will leak if not replaced when removing the cover. Ask me how I know.
Old 15th May 2013
RollTideRoadster RollTideRoadster is offline
RollTideRoadster is an unknown quantity at this point
Default great to know!
Good to know, i was noticing the other day that i had some leaking coming from the inspection cover so this is definitely going to save me a headache when i get to fixing it! Thanks.
Old 2nd November 2016
Nibelungen's Avatar
I beg your pardon but i have not understand...
Then when you remove the primary inspection cover on 09 up bike... you have to buy in advance not only the gasket but the cover as well (the gasket work only if purchased like a set)
Is it that right?
Thanks in advance and have a good day
No, just buy the gasket. Or you could get the old style gasket if you prefer.
Nibelungen's Avatar
Ok
Understood
The only difference is that the rubber gasket fit all the new inspection cover types... while the rigid one have to be specific to each of them
Thank you very much indeed
