Last Post: rezchug
0 Happy Birthday 'jzink0883'
Last Post: Lowe175
0 Marshwood Vale, 17th June 2019
0 Wet sumping?
0 Been Sitting For 5-10 years; Starts, But Dies
Last Post: Feskerlars
0 Front brake is terrible
Last Post: Hopper
0 Poweraythor alternator conversion
Last Post: saddlebagrail
0 2014 swingarm axle in earlier rubber mount
Last Post: jazzman
0 Does anyone run the Machinist Mike “hydro clutch?” If so how do you like it?
Last Post: Rolli
0 Gave up and made a bigger fuel tank (see pic)
0 Which cams ?
Last Post: gusm2
0 The White Bike is the Right Bike Thread.
Last Post: A Seabee
0 need service information for my '71 Ironheqad
0 Torque Cones
Last Post: Model H
0 Stator wire hot!
Last Post: oldboy
0 will not start
Last Post: 01rk
Last Post: sprink
0 For Sale: 2012 XR1200X
Last Post: joes95bobber
breilly888 (67), txsporty (63), michtif (54), Rabs (46)
  #551
Old 4th May 2014
T-reXL1200's Avatar
T-reXL1200 T-reXL1200 is offline
T-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant future
my 07 stumbled on startup, then I changed the battery cables. Fixed it.
Old 16th May 2014
HDFanWA HDFanWA is offline
Sportster/Buell Model: Sportster Nightster
Sportster/Buell Model #2: XL 1200N
HDFanWA is an unknown quantity at this point
Care to elaborate on your "fix"?
Old 16th May 2014
T-reXL1200's Avatar
Why yes I can! Check out:
http://xlforum.net/forums/s....php?t=1734750
I would recommend doing this upgrade. Considering you mag have to do it eventually anyway, it's not a bad idea.
Old 7th August 2014
48sportyrider's Avatar
48sportyrider 48sportyrider is offline
48sportyrider is an unknown quantity at this point
My 2011 48 never does this. It might run a little off at first if it's cold, but that is because it has an engine lol I never really let my bike warm up, I just take it easy until SKIDKING warms up.
Old 21st April 2015
andyb andyb is offline
Sportster/Buell Model: 1200 low
andyb is an unknown quantity at this point
Question
so, 2007LOW started this thread 7 years ago. his bike was fixed by H-D setting him up w/ a tuner & a better tune. it's now 2015 - my wife also owns a 2007 1200 LOW & also has the stumble while warming up. does anyone out there know if H-D has an updated calibration for this concern, w/ out having to spend $450 on a tuner?
Old 27th June 2018
ironmanx ironmanx is offline
Sportster/Buell Model: XL883L
ironmanx is an unknown quantity at this point
Is this still an issue on bikes from 2012 and newer?
Interested to know.
Reason I ask is its getting cold here now with ambient temps of a morning around the 3 to -5 deg C range and tops of 13 deg C.
I let my bike warm up for approx 5 minutes tops - or once the engine rpms drop to regular idle speed then ride it gently for another 5 or so minutes. I took a look inside the oil bag as I started it up and watched the honey rise. Seriously like honey in viscosity.
I called lube support at Penrite Oil and they said that the oil I was using (Penrite MC4ST V-TWIN 20W-50 PAO & Ester oil was rated down to -15 deg C. https://www.penriteoil.com.au/produc...w-50-pao-ester)
A bit off topic I know but was searching "cold start".
Would be interesting to watch an evo engine start up dead stone motherless cold with no rover box covers on to see how long until you see oil lubricating things up there.
Cheers
Old 20th August 2018
frankman's Avatar
frankman frankman is offline
Sportster/Buell Model: XL1200N Nightster
Sportster/Buell Model #2: XL1200C Custom
Sportster/Buell Year #2: 2004
Other Motorcycle Model: Kawasaki ZX14R
frankman is an unknown quantity at this point
I run PCV on all my sportsters, I add 5% fuel at 1500 Rpm's It makes it cold start much smoother without stumbles and stalls, it also has a feature to add the fuel for 30 seconds and up each time you start the bike
