0 Do people notice your bike?
Last Post: brettxlch
Last Post: CT XR rider
5 Why Are You Still Married?
0 Hi from NY state
0 Oil Tank Cap doesn't fit right
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
0 03 sportster front muffler Stud nut Thread size?
0 Runs rough on highway.
0 Spectro STL 75W140
Last Post: Four Speed
Last Post: 2cvandy
0 900 dual carb front head
Last Post: thefrenchowl
0 WTF Happened
0 1981 ironhead xlh PROJECT
0 Oil Analysis?
Last Post: Trailhawk750
0 JACKHAMMER 570 Cams!
5 Summer time heat
Last Post: Kbetts
0 NEW CRANK OPTION for 91-03 OWNERS: XR1200/Buell XB Crank Retrofits
0 Air Filter Soaks With Gas
0 Sportsterpedia Progress
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: JaKaL
Last Post: oupa
0 Hoo rah for Missouri.
0 stress killer
mailmanjohn (52), 93customsporty (52), markmopar (52), ironheadTX (48), Austin-W (47), dcarterjr (47), MaX_01 (35)
Old 10th October 2016
jzink0883's Avatar
Sportster/Buell Year #2: 1998
SLD,
Thanks for posting the weights of the wheels used on the new Roadsters. Reps to you.
Old 15th February 2017
jzink0883's Avatar
FWIW.
Per SLD's post below, a bare rear wheel for the new Roadster weighs 15lb-2.6oz.
I weighed a 13-spoke, 3.0x16, cast rear, wheel from a 2000 Sportster. The weight (including sealed bearings, spacer, and valve stem): 17lb-8.0oz.
Old 7th October 2018
xlecne's Avatar
xlecne xlecne is offline
Sportster/Buell Model: xlc
Sportster/Buell Year: 90
Sportster/Buell Model #2: xlc
Sportster/Buell Year #2: 2004
xlecne is an unknown quantity at this point
Originally Posted by Screw Loose Dan View Post
Just to update this thread...New Castle HD had told me the wheels were on backorder and their expected release date was 10/20 & 10/26. Earlier this week I received an email saying they were being shipped out and I'd have them by the end of the week. They arrived today!! WoooHooo!!
I'll probably weigh them some other time (I have guests coming today, so no time to dilly-dally around), but here they are:
This is sorta how it'll look...
Thanks to everyone that helped out early on this thread to point me in the right direction! Much appreciated!
Will these wheels work on a stock 2000+ 39mm narrow glide fork? I absolutely love these and just want to both them on with a bearing kit.
Old 16th December 2018
Bluto Bluto is offline
Bluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud ofBluto has much to be proud of
Nope, mid glide is required to make the wheel fit...and even if that were not the case the 120/70-19 tire on the new wheel would not fit narrow glide anyway.
(wanted to do this myself, ended up going with the new Roadster rear wheel only so far, bolt in on my 08 as it has a 25mm axle...may try making the front fit in the future. Would also require new fender)
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Originally Posted by Bluto View Post
Nope, mid glide is required to make the wheel fit...and even if that were not the case the 120/70 tire on the new wheel would not fit narrow glide anyway.
FYI - They aren't the standard HD mid glide width either. It's close, but it's not going to be a straight bolt on unless you use the Roadster front end. If I recall correctly, the hub is slightly wider than the standard mid glide hub, so the rotor will have clearance issues at the caliper. Gonna have to change how the caliper mounts or machine the hub, not sure what would be easier. I gave up using these wheels because of it (and went with carbon fiber BST's for my project).
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 17th December 2018
Thanks, good to know. Cvaria got the 16+ front wheel to work on his Sportster but it took a good bit of tinkering IIRC, he posted a detailed writeup but pretty sure it was on another HD forum.
Multihdrdr Multihdrdr is offline
Multihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant futureMultihdrdr has a brilliant future
I made the wheel and caliper spacers for the Front
Old 3rd February 2019
08nightmare's Avatar
08nightmare 08nightmare is offline
Sportster/Buell Model #2: Nightster
Sportster/Buell Year #2: 2008
08nightmare is an unknown quantity at this point
Any chance you can make these again ? I want to run these on my 2004 roadster or my FXR !
- Spending a Life Sentence Behind Bars -
Old 4th February 2019
You'll need to use Midglide Trees ... On cvaria's, the 2011-later XL1200C ("Custom") Trees were used.
